Swingarm spools on a 919?
25K views 96 replies 30 participants last post by  PHOBMAN
#1 ·
#3 ·
Ah, if the only way to get spools is to have something welded on, I think I'll stick with the swingarm lift that I currently have. I don't weld and don't want to mess with paying someone to weld them on. Thanks for the info.
#4 ·
A local shop should be able to do it for cheap. I have been meaning to get some. The bike always seems to slide off the universal rear stands. Especially when you are trying to break torques.
#13 ·
can i ressurect this thread by asking semi_gray to make some of these? With his skills, im sure he cud bang out a couple of these :clap:
was just looking at swing arm spools, is welding on bungs stronger than tapping the swingarm? is tapping the swingarm possible?
#80 ·
For the right price I'm in on the adjuster spools :)
I imagine the material is too thin is the swingarm to be structurally viable. I could be wrong but I'd say welding would be the way to go. If you prep the swingarm a good TIG welder should be able to do em up for $20.
#16 ·
I like those Italian jewels a lot and ordered a set. If any of our resident machinists (Semi Gray?) would like to borrow them and make a pattern for the good of the 919 community, I am willing to loan them out before installing them. Send me a PM and we can connect when they arrive.
#17 ·
Go for it semi_gray, I wanna be on the list when you do them!
Sent from my iPhone using Tapatalk
#19 ·
My understanding with the bolt on ones is that you drill and tap a thread into the side of the swing-arm. However this would rely on the alloy in the arm being a reasonable thickness - anyone chopped a stock swing-arm and measured?
#21 ·
Damn those are nice!!! What did they end up costing? Curious to see how the go on and how they look installed!
#22 ·
#23 ·
They were stupid expensive and totally an impulse buy. With the air mail and foreign exchange fee on my visa they came to about $225. Now let's hope they fit right and work as expected. I will report back in a week or so as I have to travel today through Thursday.
#25 ·
HOLY FLIPPIN COW BATMAN!!! Wow, they are REAL proud of those! Awful nice looking though... Damn!
#32 ·
Installed today
I like them. They are well made and thicker than stock so I ended up with slightly fewer exposed threads on the axle. There are still two threads showing so I'm not worried about that.
They will sure be handy if I ever get a stand - hey I said they were an impulse purchase! (Don't ask how I supported the bike in my apartment to get them on) Installation took about 20 minutes total. The test ride to the station to check air pressure in tires took 10.
#39 ·
Aye -- there's the problem. One of the most important reasons to get the rear wheel off the ground is to remove it for whatever reason. Can't do that with those can you? Kinda negates part of the reason to have them in the first place.
Frankly, a stand like the Phobman or a cobbled together analog is the best of all possible worlds, allowing everything but pulling the motor, and it is positively held in place, making knocking it off the stand practically impossible. And this is coming from someone who does the practically impossible a few times a week!
#35 ·
MAMBO,
what's the tankside grip material made of? is it sticky sandpaper? it looks nice, just wondering
#36 ·
It's called Gripster and made by a company called TechSpec. It's the "high fusion" pattern, not the snake skin. It's pricey but I liked it better than some of the others because it can be easily removed and stuck right back on without affecting the paint. They have a pattern for the 919 even though it's not listed on their website. I paid around $40 for the two side pieces plus another $12 for the center piece.
#41 ·
The axle goes through that nicely fab'd up aluminum slider, so when the axle is removed, the slider is no longer located and the rear of the bike drops.
Ungood.
As in Ungood Design, despite their looking very pretty.
