OEM and aftermarket brake pads.
1.2K views 5 replies 3 participants last post by  Islandboy
#1 ·
There has been a visible difference between the OEM pads and the aftermarket ones I have brought. The OEM have a thin perforated metal backing plate. I'm assuming it's for thermal insulating?
My advice is don't throw your old OEM pads away if going to aftermarket cause that backing plate easily lifts off and can be clipped over the aftermarket ones.
#3 ·
I couldn't find anywhere you could buy them separately from the OEM pads. So I suppose if you wanted them you'd have to buy a OEM pad set.
I found out what they are. A little Google search. They are called shims and are for noise reduction, brake squeal.
