So, today I was doing the pre season servicing on the 2000 RC and decided to install the OEM turn signals that Moto so generously sent me.
Well...add to the list of small changes between 2000 and 2002 the turn signals. The 2000 uses a three wire connector and the 2002 uses a two wire. The 2000 of course has the running light setup and a two filiment bulb, whereas the 2002 has a single filiment bulb.
After much screwing around I discovered that you can take the signals apart...there is a screw deep in the mount that seperates the flexible mount from the signal casing.
So I get all the innards swapped over, everything pluged in, everything works....go for a ride. While riding I look down to admire my fresh OEM left side turn signal and notice the hard shell part is upside down....it's a 2002 right side signal! Evidently Honda also swapped the wire colors...the left side wires on a 2000 are the same as the right side 20002 wires...and vice versa. It appears Honda really...REALLY didn't want people swapping signals for some reason. Anyway...it works...it's staying there.
By the way....anyone have a stock 2000 left side mirror they want to part with?
JohnnyB
JohnnyB
