After reading @marylandmike 's
GE LED Headlight install-review, I decided I wanted to do try this
The headlight I used is very similar to the GE unit but is sold by Truck-Lite. The back portion is black instead of gray and the LED holder in the front is also black.
Truck-Lite - Catalog Product : 7'' Round LED Headlamp, Complex Reflector Optics Design
I decided to try a different route after reading that the the standard H6024 light will not fit the OEM 919 mounting hardware. Instead of modifying the headlight, I decided to try another trim ring from an older Honda. I wanted to be able to replace the headlight quickly in case the LED unit failed.
4into1 had exactly what I needed.
7" Chrome Headlight Rim / Retainer Assembly - Honda CB450 CB500 CB550 CB750K
The trim ring fits the 919 bucket size wise, but uses different mounting locations. The 919 ring has a tab on top while the new ring uses a bolt. The side bolts locations on the new ring are a bit more to the front and higher.
I used a Dremel tool to cut off the tab mounting point on the 919 bucket. This allowed the new ring to sit flush inside the bucket. I then drilled a mounting hole on the top of the bucket to accommodate the new ring.
