1 - 20 of 29 Posts
· Registered
After reading @marylandmike 's GE LED Headlight install-review, I decided I wanted to do try this
The headlight I used is very similar to the GE unit but is sold by Truck-Lite. The back portion is black instead of gray and the LED holder in the front is also black.
Truck-Lite - Catalog Product : 7'' Round LED Headlamp, Complex Reflector Optics Design
I decided to try a different route after reading that the the standard H6024 light will not fit the OEM 919 mounting hardware. Instead of modifying the headlight, I decided to try another trim ring from an older Honda. I wanted to be able to replace the headlight quickly in case the LED unit failed.
4into1 had exactly what I needed.
7" Chrome Headlight Rim / Retainer Assembly - Honda CB450 CB500 CB550 CB750K
The trim ring fits the 919 bucket size wise, but uses different mounting locations. The 919 ring has a tab on top while the new ring uses a bolt. The side bolts locations on the new ring are a bit more to the front and higher.
I used a Dremel tool to cut off the tab mounting point on the 919 bucket. This allowed the new ring to sit flush inside the bucket. I then drilled a mounting hole on the top of the bucket to accommodate the new ring.
· Registered
Discussion Starter · #2 ·
To secure the trim ring on the headlight bucket, I bought another bolt and spacer from Honda. This allows the ring to fit securely to the bucket without crushing the plastic.
I then slotted the side bolts with the same drill bit I used for the top. Once this is done, the trim ring bolts perfectly to the 919 bucket.
You can now install any 7" round headlight in your 919 bucket.
· Registered
Looks great! Must be a big improvement.
How much is that light? I may be blind but could not see a price on the link that you provided.
· Registered
· Registered
That's a really decent price. Post a review of the light if you haven't already!
Cheers
· Registered
Yeah, snowing here too. Nice forecast for the weekend, though.
If I get the $s, this is a definite mod for me in the near future.
· Gran Tirono
Yeah, I installed the truck-lite on my Monster, the difference is pretty damn fantastic.
I do have one small issue with it, and that's the beam is so focused that when I lean into a turn, the beam dips out of my sight line, which at first was a little disconcerting. It might be due to the headlight angle (Maybe I have it pointed down too much or something), but I noticed that when I had it aimed higher I would get a lot more people flashing me with their lights because they thought my brights were on. Once I lowered it a little the flashing from cars stopped.
· Registered
So I followed your steps with a generic headlamp (don't have truck-lite/jw speaker money).
Did pretty well, the Emgo trim ring took some figuring out to attach it to the light, but in the end got it together. Those square nuts were a total pita to stay when attaching the bowl to the trim ring!
I dremeled away those clips, took apart the headlight and ring to use the ring and mark the top hole, drilled the sides up a bit, which sucked a bit, I gouged up one side a bit, and the light looks like it is rotated about 3° off centre :(
I really do like the look of it. I didn't have anything to solder/hook up the halo yet, but will probably get that on next weekend.
Sent from my iPhone using Tapatalk
· Registered
Do you know where the spacer and bolt were off of? Thats the only thing i am confused about! Part numbers would be fantastic!
· Registered
They are from the 919.
There's already 2 bolts and a 2 spacers on the headlight bucket. I bought a 3rd one and installed it on top of the bucket
Sorry to be a bother. Found a good deal on the truck lite 27270C so i think i am going to be following your DIY to a T.
Still had 2 questions. The hole on the top of the bucket....was the hard to do? Id really hate to mess it up!Im guess you dont know the drill bit size you had to use. Did you have to enlarge the other holes also?
I'm assuming I would need part 18 and 25?
· Registered
You need parts 20 and 25. 18 is the standoff/spacer for mounting the bucket to the brackets.
Drilling the new hole isn’t too bad, just find the right size bit for the sleeve, take the top two tabs off the bucket with a Dremel and offer up the headlight ring. I marked it from the inside and then drilled upwards with a small bit, then opened it up with on the right size from the top, put the sleeve in the hole and tested it.
The side holes will need to be made bigger, that’s where my bucket doesn’t look too good as I gouged those areas a bit.
If I did mine differently, I’d put the bike on a paddock stand (or if you’re a lucky one, your centre stand), as I think my light is a little skewed when bolt upright.
1 - 20 of 29 Posts
