Are there any tire suggestions for my new 9'er? The last bike I had loved a 'lil wider back tire but this one seems perfect. What kinds of tires are perfect for the 9'er?
Stock tires at max pressure - not so goodAre there any tire suggestions for my new 9'er? The last bike I had loved a 'lil wider back tire but this one seems perfect. What kinds of tires are perfect for the 9'er?
Stock size Pilot Powers with 32f/36r - priceless
Data based on a 210-220 lb. rider!
36/42 is purely a liability dodge based on the required pressure to meet the maximum load rating of the tire.Jumping on this discussion late! On my Michelin Pilot Road 5's, I ran 36/42 typically. Looking back, it was probably a little high.
Now, I just put Dunlop Sportmax Q3+'s, and am running 34/32 and love it! I have less chicken strip in 100 miles than I got the entire 6,500 miles, and feel much more confident on corners.
The higher numbers are for maximum load rating only.Don't forget the speed rating of those tires...."Z" I think so the higher pressure recommendations are also in support of that. Z is good for at least 149 MPH. You might not want to run that fast with 30 PSI in the tires.
I run close to 160 pretty regularly on my race bike with 25 PSI in the rear tire... and guys on 1000's are closer to 180 with similar pressure... and that's 25 PSI off warmers, so probably closer to 20 cold.Don't forget the speed rating of those tires...."Z" I think so the higher pressure recommendations are also in support of that. Z is good for at least 149 MPH. You might not want to run that fast with 30 PSI in the tires.
I don't remember that one but it would be interesting to see if any context was part of it.I run 34f/40r on Pilot Road 4 tires only because I read on here long ago to go ~2psi lower than OEM spec. Can't say I'd notice the difference though.
For solo local riding those values will make little difference from the characteristics if 36/42, as in sacrifice of everything except liability related in terms of a milkable corporate entity.
