Some of you know, my transmission self destructed at CMP this past fall.
I did an engine swap rather than a rebuild because the Parts for the Transmission alone were rediculous $$$. I went from an 01 to an 03 motor which meant the electronics had to be changed as well.
Tonight, she fired up. I did not let it run longer than 10 seconds, but that is because I do not have the velocity stacks yet or several other little parts. I just wanted to know my wiring was right.
Tuesday, my forks should be back from Dan Kyle, and I just mounted my Thermosman Penske on the rear. I am finally calming down about being able to have this thing together for Jennings.
