If the engine is not using oil, you are running pump gas, and have factory spec plugs, something is wrong of the plugs are not good for 24 K kms or 16 k miles.Check you manual again, my manual says check plugs at 12,000 kms (8,000 miles). Replace at 24,000 (16k miles).
Obviously if they look crap when checking then replace, otherwise good to go.
Just wondering how you think a metal that is stronger, harder, and can withstand higher temps than standard plugs, cheap?id rather run a good quality standard plug like the ones that comes in the bike rather than cheap iridium.
if the 919 needed iridium it woulda came with an iridium... there is a reason mr honda used a standard style plug to begin with and ill be stickin with just that as it works like a charm.Technically if your gap is correct, no corrosion is present, you can clean them and keep using them for a long time, but...
Though he died well before the 919, I would say Honda, just like nearly every other manufacturer uses standard plugs, because standard riders don't really care that much about their machines. But for those who want to give our prize possessions every extra goodie they can, even if being minimal improvement, there are parts/accessories that improve on the technology available at the time the bike was made.if the 919 needed iridium it woulda came with an iridium... there is a reason mr honda used a standard style plug to begin with and ill be stickin with just that as it works like a charm.
My local stealer quoted me $12.99 for them. I asked him, "for all four, right?" and then walked out when he said no...they can be had at many auto parts stores for less than $5 Napa, Checker, Autozone....My owner's manual does say to replace plugs at 8000 miles/12.8Km. Here in Canada, the Honda dealer wants $15 plus tax for these NGK CH9EH-9 plugs. I will be cleaning them and checking the gap.
With the mentality of; do motorcycles need to be improved from their basic design, you should apply for a job with Harley-Davidson.
It's like Hot Sauce, does pizza need to be splattered with it? No. Does it make it better? Yes.
so your telling me that The engineers wernt thinking of the necessary plug when making the 919? So that is why they just stuck an iridium plug in my CRF250x cus the figured why not? its a race motor so we gotta put an expensive plug in it even though it doesnt need it? I highly doubt that.Though he died well before the 919, I would say Honda, just like nearly every other manufacturer uses standard plugs, because standard riders don't really care that much about their machines. But for those who want to give our prize possessions every extra goodie they can, even if being minimal improvement, there are parts/accessories that improve on the technology available at the time the bike was made.
alls im saying is that if the 919 needed special fancy plugs to run properly it woulda come with it... exactly like if it needed 91 octane (like my crf250) they woulda specified 91 and not just the 87 regular.
