I have a set of Dan Moto carbon cans they don't get too hot. You should be fine.I am thinking of a set of saddlebags also, currently I have stock exhaust so no heat issues but if I go with a danmoto set of canisters will they get too hot and melt them?
anyway to get a few more pics? sorry but i am really interested in getting some soft (easy on easy off) bags for the 919... this would be my first time buying something like this.... im used to the hard bags that mount on brackets.Not a great pic of the bags, but I like them and they work really well. Easy on/off, I put the straps under the seat, and the heat from the exhaust doesn't seem to cause any problems. Firstgear Onyx.
I've just got a set of soft bags. Motocenter Sport Bags.
They work great and expand quite a bit as well. Can definitely haul quite a bit in them, not bad for grocery trips even.
I didn't want to bother with mounting brackets, etc on my 919, especially with the occasional track day, more of a pain to take off and put back on.
If I plan on doing real long trips a week+ at a time, I'll probably look into something like an FJR 1300 with hard cases.
Here it is with my tank bag as well:
IDK about aftermarket slip on, but I've had my soft saddle bags on for years and never had a problem. They do get warm, but there's a non-cloth surface on that side. It's some kind of ABS/plastic stuff with canvas for the rest of the bag.Are soft saddle bags safe from the exhaust heat?
Do you need to use a heat shield over the exhaust?
For reference I have an aftermarket slip on (not carbon).
Thanks, my exhaust definitely gets hot after an hour of ridding.IDK about aftermarket slip on, but I've had my soft saddle bags on for years and never had a problem. They do get warm, but there's a non-cloth surface on that side. It's some kind of ABS/plastic stuff with canvas for the rest of the bag.
With aftermarket, you might want to add something that'll let some air pass, simply having an air gap makes all the difference.
I don't know how hot your's gets, but what I was thinking about was to add something to the back of the bags instead of to the the exhaust. The reason is that you can take off the bags and be right back to stock or wherever you were.Thanks, my exhaust definitely gets hot after an hour of ridding.
Do you think I need something like this?
https://www.revzilla.com/motorcycle/dryspec-universal-exhaust-heat-shield
What frame did you use for the SE-720 cases on your 919 and did you add anything to the cases for them to attach?I went all "adventure-style" with my Seahorse SE-720 cases.
Cheap too. :bliss:
