hondad, thanks
the reason for the question is this. with the availability of rc51 forks becoming harder to find at decent prices. i've been looking at alternative usd forks to use for the 919.
what i've found is 2006-2007 gsx-r 750 inverted forks are black,738 mm long from axle c/l to top cap, and have 1000 kg/mm springs from the factory.
now i just need to find the offset #'s for the rc51 clamps.
btw the gsxr 750 bottom clamp has a 28 mm bore for the head tube so if by some strange chance the offset and the widths were the same that would be alot easier for the swap guys to bore the hole to 29 mm than what they are doing now with the rc51 triples.
also the front wheel is a 3 spoke that is close to the 919 design but has 310 mm radial brakes.
just looking at options
I find this really interesting.:thumbup1:
I used your "suzuki fork matrix" from another thread and checked around. Turns out I have a friend with a complete K6 GSXR1000 front end.(forks,tripples,brakes,steering damper,controls,fender,wheel etc.etc.)
I would love to run them either with the gsxr clamps and the 9'er stem....or with my rc51/954 combo since both are 50-54mm.
Do you guys think, Is an overall length of 720mm to short for the 9'er?
I read somewhere the 954/929 is closer to 700mm and considered by many to be to short.
