Loosen the bleed screw, squeeze the lever, tighten the bleed screw, release the lever, loosen the bleed screw, squeeze the lever, tighten the bleed screw, release the lever, loosen the bleed screw, squeeze the lever, tighten the bleed screw, release the lever, loosen the bleed screw, squeeze the lever, tighten the bleed screw, release the lever, loosen the bleed screw, squeeze the lever, tighten the bleed screw, release the lever, loosen the bleed screw, squeeze the lever, tighten the bleed screw, release the lever...
