1 - 20 of 43 Posts
Good afternoon ALL,
For the past few weeks I'm getting a noise when moving off from a stop. It sounds like "bock, bock, bock" (sorry that's the best interpretation I can come up with) then it seems to disappear when I'm up to speed or perhaps I can't hear it 'cause of the wind noise, etc.
It's seems like it's coming from the rear of the engine area or rear wheel, but not entirely sure. I usually use the clutchless method when upshifting and clutch when downshifting.
Engine oil level is good,
Rear break caliper is secure,
Clutch is not slipping,
Noticed a crack in the exhaust mount bracket @ u/s of engine block,
Chain is adjusted properly,
Any suggestions??
Peace and ride safe
I'd pull the seat & have a look inside the rear cowl
...sounds like you might have a chicken trying to hitch a ride. :laugh:
LOL............that's really funny. OK can we get back to what may be the problem.
sorry man, I'm an ass-hat... couldn't resist. :lol:
I'll give it some serious thought & report back if I come up with something
Good afternoon ALL,
Is there a chicken in your intake?
It may pop if the exhaust is shifting around, but I would think it would be a single pop until hitting a different gear.
Sure it's adjusted. But has it been lubed properly? How old is it? When did you last service it?
Wat u talkin 'bout??? NO CHICKENS dammit!! I should have seem this coming.
Let's stay focused, please.
Administrator
Chain/sprockets.
Like already stated, I'd check the chain and sprockets. When my chain was worn out, it made noise that was only audible from a dead stop or from a very slow rolling start.
Is there any way you can replicate the noise in a more controlled setting? Maybe put the bike on a secure stand (center or swingarm) and reproduce the noise.
Does it really bock like a chicken or is the sound more mechanical.
Why not?
is it a constant rate or does it speed up and slow down as you accelerate? is it a rubbing or grinding or mechanical?
a little more info could be helpful.
describe it the best you can or more completely.
Discussion Starter · #12 ·
Hmmm, yes it sounds like chicken but a chicken that would have a really deep bass tone.
Picture Barry White immitating the sound of a chicken......I know, not the prettiest picture but you get the idea.
Discussion Starter · #13 ·
Only hear when I'm moving off. Not grinding or rubbing, more like low deep knocking, hence the "bock" reference.
Administrator
Chain/sprockets.
Discussion Starter · #15 ·
OK, thanx. I'll do inspection chain/sprockets later tonite.
I want you to look for hooked teeth on your sprocket.
Discussion Starter · #18 ·
Will do. Hooked sprockets are more likely to be on the rear, front or either?
Administrator
I've had my 9er do what you describe twice. I looked it over and couldn't see anything wrong as far as wear. Replaced the chain and sprockets and it went away. I knew I was reaching the limit on mileage and wear so it wasn't a great risk anyway. Sprocket teeth looked just a touch pointed. Once the chain was off it was pretty easy to tell it was worn.
I'm thinking more on the rear. When a sprocket is in bad shape, it will have a tendency to hold the chain roller then let it pop loose under load of take off. That is exacerbated by a tight chain.
1 - 20 of 43 Posts
