I have a Hornet 919 date 2002 for Asia market-where the law limit speed under 180 km/h.
While the one for European can go maximum 260km/h (see pictures).
Anybody have ideas how to derestrict the limitter in my bike.
Thanks so much for your helping
This is exactly what I'm thinking. If this is the solution, perhaps one of the members here can help put this together for you. But!!!! Got to make sure that this is the solution. Any experts here?
Remove your tail section & undo the T shaped cover attached (4 push pins) on the bottom of the tail section right behind the battery. Under that there will be a black ECU box with a gray connector & a black connector.
This mod is best done with the PCII, as you can do the mod by splicing into the PCII harness instead of the ECU harness & if you ever need to undo the mod you can make it look 100% stock
You can obtain your own connectors from a cd-audio cable (pictured below) as it has the perfect size connectors to match the ECU pins.
Another solution that I'm thinking to use the speedohealer to convert from km to miles.When I go at 100 m/h the signal send to ECM only 100km/h it mean I can go maxinum 180 m/h -> 180x1.6 = 288 km/h
I write an email to the techinal engineer of speedohealer for asking
And this is his answer
Hello,
Yes, if you enable the SH''s "kph to mph" conversion mode, e.g. 140 indicated
on your meter will mean 140 mph road speed.
Probably it will also by-pass the speed limiter.
However, we do not have information on whether there is another kind of
restiction (e.g. HP) on this bike for the Asian market.
Kind Regards,
/Norbert
HealTech Electronics
Anybody have experience with this problems.Please help me
Thanks a lot
Buy new ECM it mean I need to buy new HISS lock,seat lock,tank lock... it too expensive.
I think the bike for Asian market only have 1 speed limitter inside,and I want to disable it
[QUOTE = "NewSol, сообщение: 123111, участник: 1509"]
Покупка нового блока управления двигателем означает, что мне нужно купить новый замок HISS, замок сиденья, замок топливного бака ... это слишком дорого.
Я думаю, что у мотоцикла для азиатского рынка внутри только 1 ограничитель скорости, и я хочу его отключить.
[/ ЦИТИРОВАТЬ]
Тоже хочу это сделать , у кто может помочь ? залить европейскую прошивку в ЭБУ
This is an older thread, you may not receive a response, and could be reviving an old thread. Please consider creating a new thread.
Related Threads
Sportbike Forums on WristTwisters
678.5K posts
10.2K members
Since 2006
A forum community dedicated to all sportbike owners and enthusiasts. Come join the discussion about performance, modifications, classifieds, troubleshooting, maintenance, and more!
