1 - 20 of 29 Posts
· Registered
Hi,
Iv'e been a silent member for some time now, mostly searching info for mods and maintenance on the 919.
Although forums seems to be a dying breed, there is some great info on here and suprisingly some activity.
So I bought 2 years ago my first bike with 24K km on the clock.
The bike was not in bad shape but the paint has seen better days. Previous owner stored it outside with little to no protection.
The day I bought it:
158244
First week owning this bike, I was already on this forum looking at popular mods. So far, I went through the following:
  • Bafflectomy
  • Flapper mod
  • Pair plates
  • New mirrors
  • Tail tidy (cutting down the oem unit and bending new license plate bracket)
  • Smoked LED taillight with integrated flashers
  • 520 17/44 Chain & sprocket kit
  • Luimoto seat cover with gel insert. The original was ripped pretty bad and would be a giant sponge on rainy days.😨
158248
  • Removed the Givi case and rack as I mostly ride to work and back. Kept it as it can come in handy on long trips.
  • Removed the rear grab handle and replaced with 3D printed plastic snap-in covers.
  • Spent too much time searching the great cave of Ali Baba to finally find quality motorcycle flashers from China. They are actually top notch quality and easily visible in bright daylight. E marked and called "Pazoma", probably factory rejects from the other well known brand....🤗
158245
- FX-R 3.0 Projector retrofit with 6000K HID, would not recommend using such a bulky projector but the results are well worth it! I dont normally ride in twisties at night so the sharp projector cutoff doesn't bother me much. The highbeam floods enough light all over the place that it basically solves the issue.
158254
158247
- I also just started a RC51 front end swap!
Used a CBR929RR lower clamp and needed to extend the stem by 25mm.
To mount the OEM headlight, I drilled two holes in the lower clamp for the rubber insulators and 3D printed two brackets to secure the top part. Making this front end swap fully reversible back to stock.
They bolt between the upper clamp and ignition switch and have threaded holes to mount the OEM speedo also.
158251
Fully bolted up it looks like this. I will be printing a plastic cover to cleanup the area surrounding the ignition. Making the speedo blend better with the clamp and also, I will integrate a new mounting point for my Quadlock phone holder.
158252
158253
158250
Hope you enjoyed my intro, feel free to ask questions.
I am open to criticism as long as it stays polite and constructive.
I will be using this thread as my build thread and post progress pictures of my various upgrades.
More to come.
Cheers!🍺
· Registered
Thanks, really looking forward to have it back on the road!
Tonight I spent time on SW and got busy on that ignition switch cover I was talking about.
It will be secured via the two holes in my upper clamp. I wont miss seeing them ever again.
Printer just started, I should wake up to a fresh part tomorrow!
158260
Oh and I also printed a gramophone intake the other day...
158262
158263
Cheers 🍺
· Registered
Welcome.
Nice build. Great idea 3D printing the air intake.
I made a modified air intake by grafting a aluminium stack onto a cut down snorkel mount. But 3D printing the entire unit is an excellent idea. I’ll look into getting one printed.
I took the inspiration off your bike for that intake. But I didn't want to hack into the oem intake unit.
If you want the 3D file for that intake, let me know.
Printer has finished baking my part!
Sent from my SM-G950W using Tapatalk
· Registered
That's a really nice bike progression!! Where did you find the RC51 front end? Those seem to be rather unicorn-ish these days...Are you planning on keeping the 919 master cylinder? I upgraded mine to a 999 Brembo unit and honestly, it was all I needed to be happy with the brakes.
How did that Luimoto seat cover treat you? I'm considering something similar. I first thought about Sargent but that's just WAY too expensive, and probably more than I need.
· 919 Rider
Glad to hear I inspired you to 3D print that air intake. You’ve inspired me to get mine 3D printed.
Thanks for the offer regarding the 3D file. I just might take you up on that.
Your bike is going to look cool once you’ve finished.
Well done mate.
· Registered
I got lucky looking at FB marketplace, the guy was parting out his track bike after crashing it.
Forks were not affected, only a small grind on the axle end.
Clip-on tubes took a beating in the crash but they are still usable until new ones arrive.
For the seat, I did look at buying a used Sargent seat but with nothing available at a reasonable price.
Forget buying new, you lose all comfort with a gaping hole in your pockets.
I went the "lazy" DIY route with the Luimoto, saved myself the hassle of making/stitching a nice cover. I did cheap out on the gel insert. Found a gel pad about 30% larger, same gel, half the cost. Had enough gel to put an insert in the passenger area!
I havent looked seriously at changing the master cylinder yet. Its on the list somewhere, but I'll enjoy the current upgrades and when they start to feel boring, I'll spice things up again! :sneaky:
· Registered
Finally back on the road, still needs attention tominor details. But DAMN its a completely different bike! Whoever hesitates doing the fork swap, just DO IT!
Still missing the front fender.
The one that came with the forks was bright red, so I decided to paint it black and it fish eyed really bad on me... I did go quick on the prep prior to painting.
· Registered
In what way did you find the bike was transformed?
Either way, nice ride!
· Registered
Discussion Starter · #13 ·
The front end is much more responsive and accurate. I feel like I am doing less corrections when turning, it just goes where I want effortlessly. Throwing the bike left to right seems easier as well.
Feels much smoother flying over the Quebec roads. For those who drove in QC, you know what I am referring to. Just horrible road financed by our hefty taxes.
Some changes may also be attributed to the riding position that was drastically changed by the clipons.
· Registered
Discussion Starter · #14 ·
Forgot to post an update on the finishing of my printed intake.
To get rid of the print layers and smooth to an even finish, I sanded down the whole thing with 320 grit. Then exposed it to acetone vapors for about 1 hour. It melts the plastic slowly forming a skin. Then as the acetone vapors exit the plastic, it hardens back to a glossy smooth finish. Works well for printed ASA and ABS.
· Registered
2003 Honda Hornet 919
Very impressive. I know it’s a couple years later, but I wondered if you still have the files for your printed parts? I love the new intake.. I haven’t progressed to ABS on my printer but I don’t mind the layered look of PLA. If you still have the file, I would love to get my hands on it. For that matter, any 3d files you’ve put on your bike, if you’re willing to part with them
· Registered
2006 Hornet 900
The snorkel sounds like an excellent mod! I bet the intake sounds much better. Would you mind sharing the file? I'd love to get one printed myself.
· Registered
Discussion Starter · #20 ·
Hi everyone,
bringing the post back from the dead.
Lots of changes occurred past months in my life forcing me to put aside riding and wrenching.
Without going into details all I have to say is that mental health is extremely important and it shouldn't be ignored.
When people need help, their signs are often very subtle due tot the shame they carry, but don't let that be an indication of the size of the pain they are living.
Listen to them, be there for them, just like you would want them to be there for you.
Moving on to brighter things....🌞 🙃
I will send you a link to the print file by private message shortly.
Love what you have done to your bike. Do you have any plans to make any changes to your exhaust? Exhaust is my next mod. I’m wanting to put a header on my bike.
I picked up a set of race headers with twin carbon Scorpion mufflers from a 900RR on FB Marketplace for 100$ a while back.
They looked in really bad shape when I got them. I started repolishing all of the stainless, bought all the supplies to repack the mufflers but still has to be done.
Its also missing 3 of the 4 header flanges, so I'll have to make new ones.😒
If I find any pictures I'll post them.
Cheers!
1 - 20 of 29 Posts
