WristTwisters.com banner
1 - 18 of 18 Posts
Managed to kill a Honda..
Last year my chain broke while I was riding, which shattered the guard part of the case, but didn’t cause an oil leak. The chain did bind up a bit around the front sprocket, but as far as I could tell it was spinning fine after I removed the chain.
There was a bit of a sound when I ran it with no chain to check for damage, but I as hoping it was just rattle caused by lack of tension. I slapped a new chain and sprockets on hoping for the best, and now I’m experiencing a significant engine rattle. I can’t tell if it’s just cam chain slap or if it’s something worse like rod knock.
Oddly enough, when I shift it into 1st, the noise stops completely, until I let off the clutch, then it comes back and increases with RPMs.
Here’s the link: https://youtu.be/ZVANQxRPOsg
Any suggestions would be appreciated.
Using logic, if the noise stops when the clutch is disengaged the cause is downstream of the clutch, so no camchain or crankshaft problem. Determining the etiology of the noise is going to take some doing, but is limited to the transmission / oil pump / water pump which at least narrows the focus.
Sound is a good way to narrow the focus further. At idle the crankshaft is turning ~1200 RPM, or 200 RPS (Second). This rotates the clutch at ~800 RPM, or 13.333... RPS (1.52:1 reduction). Counting the cyclic noise in the video against the counter yields a period of 0.5 second. Given that information the task now is to find a transmission component that makes a full revolution at that RPS. Here is a good source of information that can shed some light on the problem : https://www.gearingcommander.com/ It has listings for thousands of motorcycles' drive lines. And there it was: the second gear on the countershaft is twenty six teeth, resulting in a period of 0.5 second. It's located next to the output bearing, which means that when the chain wrapped around the front sprocket the forces flexed the bearing, countershaft, and the engine case enough to damage the teeth then in contact with the matching mainshaft gear, damaging at least two teeth.
I may be off base here, but logic indicates it is a strong possibility. Frankly, I hope I am wrong due to the fact that the engine will have to be partially torn down to effect repair.
Good luck. You're going to need it.
Discussion Starter #4
Thanks for the in-depth analysis. I’m fairly certain I was in 2nd gear when the chain R.I.P.’d, so that would make sense. I figured the transmission was fine because when I tested it after installing the new chain it went through the gears normally. Well, at least if I have to tear the engine down I’ll have an opportunity to learn something...
Bring a dentist along with you when you crack open the lower.
Hahahahahahaha! Never let anything take away your sense of humor, including that transmission!
This was a really good call!
Cook yourself another one of those 2 inch thick steaks and have some beerS.
Mmmmmm mmmmmmm mmmmmmmm mmmmmmm mmmmmmmm mmmmmmm mmmmmmmm mmmmmmm mmmmmmmm mmmmmmm mmmmmmmm mmmmmmm mmmmmmmm mmmmmmm mmmmmmmm mmmmmmm mmmmmmmm mmmmmmm mmmmmmmm mmmmmmm mmmmmmmm mmmmmmm mmmmmmmm mmmmmmm mmmmmmmm mmmmmmm mmmmmmmm mmmmmmm mmmmmmmm mmmmmmm mmmmmmmm mmmmmmm mmmmmmmm mmmmmmm mmmmmmmm mmmmmmm mmmmmmmm mmmmmmm mmmmmmmm!
Come on by. Dinner and drinks are on me!
If I could I would!
When you are near, come on over here!
Goleta California!!!!!!
I'm getting ready to put one on the grill in a half hour.
Meanwhile, here in Calgary, the freshly cooked roast beef in our kitchen is near finishing its post oven cook and will soon be carved.
I'm thinking of cutting a slab 2 inches thick and pretending......................
Do you use a nice creamed horseradish by any chance?.
No I don't.
Generally we season the roasts such that horseradish wouldn't be the best addition.
I do like horseradish though, preferring a good and hot simple ground one.
The creamed ones I've been exposed to can be eaten alone by the spoonful.
I like more edge, but not off scale.
I was thinking about prime rib and horse radish today and thought of your post.
I found some horse radish with an edge like you were talking about.
The name of it is simple: Atomic
That's it. That's all.
I can just imagine what that must be like!
So far, the hottest I have ever had was home made stuff we used to get from Mennonites in the St. Jacobs area of Ontario, circa 60s into the 70s.
(Whenever we make a trip to Ontario, we still go to the same two farms for summer sausage and maple syrup.)
1 - 18 of 18 Posts
