Yes, your idle has the usual 919 beat to it, and yes, the difference has been brought about by way of the starter valve sync. It's a PITA to do, but yields immediate rewards.
You'll be happy you did. After you've finished.I've been meaning to do this. Have a Carbtune ready to go just haven't bothered to do it yet. I've got the tank raised for a few other jobs right now so I may do it while access is easy.
Stock here. I'm going to use a combination of the factory service manual and the post linked above to get it done.@opengl hello again! I also have a carbtune and that sync is on my list! Good luck with yours, do you have a PC3 or running stock? Do you know of a good guide for the 919? I've searched around and haven't found anything with photos / video associated with the procedure.
K1w1Boy has given you the succinct answer.I don't have a PC3 unfortunately. Is interfacing with the ecu / doing a throttle position sensor sync necessary?
