1 - 20 of 115 Posts
· Registered
The cutout or stalling problem when warm, cold or otherwise was NEVER caused by the Dynojet Power Commander 111. This was purely a faulty power supply within the right side switch assembly on the 919. Specifically the starter defeat feature when the kill switch is off, the contacts related to that, and their poor conductivity. Having ridden a full season and now well into the cold I can positively confirm that I have solved this issue.
· McTavish
Thanks for the above post.
What all did you do to remedy your situation?
New parts?
Clean the contacts?
Any tips to pass on?
How did you ultimately determine the issue ? meter checks? parts swapping? whatever ?
· Registered
I don't buy it. The PCIII is involved. Mine was hard to start. Removed the PCIII--instantly & permanently fixed to this day. No changes to anything else. Starting test were immediately before removal & immediately after. The PCIII may not be acting alone, but it is involved.
· Registered
Discussion Starter · #4 · (Edited)
Its an update, there are previous posts regarding this topic that have already covered these questions and other opinions several times.
If you have a PC111 installed and prefer to keep it, but are having starting issues you want fixed.........do a cold start search, happy reading.
· Premium Member
I'll confirm ^^ that above. When I sold my bike I had taken the PCIII off. Cold start gone instantly.
No other change to the bike.
· Registered
Discussion Starter · #7 · (Edited)
Brilliant, especially for a moderator.
This is a simple and easy to prove power supply malfunction,
as stated by Dynojet from the beginning.
Get a used right side switch assembly for a cbr 600 or similar,
they are cheap and plentiful. Carefully break the connector to free the pins.
Open the headlight and disconnect the right side switch, plug the cbr pins in and you have just solved the issue.
· The Cripple
as stated by Dynojet from the beginning....
yeah because they don't want to admit that their product is the actual problem/issue.
No you haven't, because the only changing variable when the problem pops up is the pc3 itself.
If your "solution" is a permanent fix, then my "solution" of just holding down the start button a few seconds longer is an even better fix because you don't have to do anything. Not to mention its free!
Again, don't buy it. Been tested and proven repeatedly, the culprit is the pc3 itself.
· Premium Member
What, moderators can't have opinions? When was that rule made? Lol...
And explain how my starter switch worked like it did on day one after removing the PCIII and the cold start went away after removing said PCIII? That was my exact experience.
Don't get me wrong, I'm interested to see the results of a new switch on a bike that has the issue, without tampering with the PCIII, but when just removing the PCIII from the equation solves the problem, well, that's pretty easy math.
Next guy that has this issue we need to send him a switch.
· Old, Bold rider
Found the source of contention here. What everyone seems to have missed is apples and avocados are being compared, causing the misunderstanding. If it's hard or impossible to start it is probably the PCIII. Cutting out when riding (Meaning it has already started: an entirely different animal!) is the kill switch. Installing the Yamaha kill / start switch as seen in the OP photo cured the cutout problem, but would not necessarily cure a cold starting problem, which has absolutely nothing to do with the kill switch. How do I know? Look at the wiring diagram -- the starter circuit is powered by battery voltage supplied from the output side of the kill switch which also picks up the engine stop relay. If when the starter button is pressed the engine cranks over the kill switch is functioning normally and is not the cause of any problem.
If, however, the engine dies while riding the kill switch is a likely culprit (amongst a variety of other possible malfunctioning components), indicating poor contact in the switch that when affected by vibration or other external forces disconnects power to the engine stop relay, which does its job of stopping the engine when deenergized.
Just trying to get everyone to realize they are on different pages!
· Registered
Discussion Starter · #11 · (Edited)
My PC111 is over 10 years old and mounted in a less than ideal location directly underneath the seat cowl. Throughout, its been neglected, exposed to constant heat from the silencer, annual cold winter storage, water spray when caught in the rain plus some significant pounding from a stiff rear spring setting. Also, considering the many hundreds of power fluctuations its received from repeated starting attempts, the thing's an effing champ, and I came very close to stomping on it.
On the other hand, Honda has supplied a switch that worked fine when new but began giving problems like power to the headlight for example. I cannot define exactly what the switch is doing wrong, its a make before break thing, but I guarantee changing it for a better one will make your 919 start first time, every time.
Your lack of comprehension is astounding, but you probably didn't get that.
· Registered
Discussion Starter · #16 ·
read it ALL again, seriously. u will need the matching throttle housing, or u can zip tie the new switch to your mirror and keep your old throttle ha, and for those of you that drilled your handlebars...........
· Old, Bold rider
Granted. I did not do any research before responding. Now I have. Here's my take on it, and while testing it is impossible for me (no PCIII on my 919) it does make sense.
First, a basic assumption: installing a starter / kill switch assembly from a CBR cured the problem. Cool. The question is how did it cure it? First, it's probably a new or newer switch than the one it replaced and the contacts are relatively pristine, guaranteeing a cleaner voltage from the kill switch to the load it supplies. Always a good thing, but maybe not the whole story. Part two is the electrical difference between the two switches: stock, the power to the starter button comes from the output side of the kill switch which will disable the starter when the kill switch is off. The CBR switch does not have this function. Otherwise, they are electrically the same. On the 919 all the kill switch powers is the engine stop relay and the starter relay.
Next, some basics about relays. All conventional relays have two operational voltage ratings. One is pull up voltage, usually listed as the coil voltage. It creates a powerful enough magnetic field to attract the steel armature and make contact. The second rating, rarely specified outside the data sheet, called hold voltage. It is the minimum power required to maintain contact, usually about 60% of the pull up power. This will become important later. Another characteristic is when a relay is deactivated it generates a negative voltage spike, or "back emf" in the same way an ignition coil does which can go as high as -250 volts for a few milliseconds. Generally, the higher the current rating of the contacts the stronger the back emf will be.
Putting it all together, when the starter button is pressed the relay applies battery voltage to the starter motor. The load drops the battery voltage to about 10 volts if it's in good shape and it's warm out. The colder it is the harder the battery has to work to spin the motor, and at the same time the weaker the battery is. Under these conditions the voltage may come close to the hold up voltage of the engine stop relay, but still not low enough to drop it out. That is until the starter button is released, the relay deenergizes, and a negative voltage spike is generated which will be sufficient to arc across the just disconnected starter switch contacts and apply itself to the output side of the kill switch. Under normal circumstances it would be absorbed by the voltage line from the fuse box, but with contaminated contacts in a ten year old switch the bulk of it may apply to the voltage holding the stop relay closed, temporarily deenergizing it. The ECU is "hardened" against this with high value capacitors that keep it alive until the relay reengages. The PC, however, may lose its initialization and cut power to the injectors, killing the motor.
If this is the case, and keep in mind this is all speculation, how to cure the problem economically? Simple. All that needs to be done is eliminate the back EMF from the starter relay by adding a shunting diode to the switched positive line at the relay to ground with the cathode (banded end) connected to the positive line of the coil. It will ignore the starter signal but bypass the negative spike to ground. No spike, no stop relay dropout.
As I said before I can't test this, so if someone with a PC who has the cold start problem kluge this up for a quick test? At most it would cost a dollar or two for a 1N4007 diode and take maybe ten minutes to hook it up. At worst it will have no effect.
· Premium Member
Rob, if you would be kind enough to provide a simple diagram I'll be the test subject. Mine has the cold start issue in a big way since it got colder this year, I had to start it at least five times last Friday before I rode. If I can cure it with a diode I'm game.
· Old, Bold rider
The attached thumbnails are of the starter relay gang plug and an edited schematic concentrating on the starter circuits and how they relate to the engine stop and starter relays. Included is the 1N4007 diode and its orientation. The lead at the banded end attaches to the Yellow / Red starter wire, and the other end to a good chassis ground.
For a description of the method of making a connection to a female terminal including how to remove it from the connector body: http://www.wristtwisters.com/forums/f94/599-headlight-8592-3.html
Post #86 on the third page. Too lazy to duplicate that here.
For experimental purposes I usually just jam a wire or test probe I want connected to a particular circuit into the well the pin is in, usually resulting in a sufficient if very temporary connection, and jump the anode lead to the nearest bolt head, in this case the 6mm bolt holding the coolant header tank on the other side of the backbone. In this way if it works (crossed fingers) you already have the setup and just need to make it permanent. If it doesn't ... well, that's what experimentation is all about. At least it will only take about a minute to remove it, shake your head, and start at square one again. There must be a solution somewhere!
Incidentally, the 30 amp main fuse is in the picture, and the exposed 5mm allen bolt is the battery positive connection, where my battery tender positive lead is connected.
Here's hoping.
Oh, and the turbo Encabulator is child's play compared to this! Unless, of course, the pitch gyro magamp saturates, precessing into the yaw domain and the inevitable happens: Descartes contribution to 17th century rationalism was neatly negated resulting in a massive temporal chain reaction, the foundation on which our civilization is built crumbles, and chaos rules the next two centuries. At the very least. I hate when that happens!
1 - 20 of 115 Posts
