1 - 3 of 3 Posts
Does anyone know what the orange/yellow wire going from the ecu to the clocks cluster is used for?
I'm doing a clocks replacement mod and this is the only wire that's left. I 've searched high and low for this without any luck. Please help!!!
This is part of a much bigger project: cb919 running on 954 ecu and throttle bodies with cb1000r clocks, so I need to eliminate things to troubleshoot as much as possible...
Thank you sooooo much!!!
Discussion Starter #2
Anything...??? Anyone???
I'll even settle at other honda models to get a hint as usually colour coding is the same. As long as the orange/yellow wire is going from the ecu to the clocks.
Wrenchin
From all the diagrams I could find, that is a European specific wire code. May have to get in touch with a tech over there to find out. May be an option only offered over there. None of the US diagrams I could find show that color combo.
1 - 3 of 3 Posts
