1 - 11 of 11 Posts
Does anyone know if the BrakeAway cruise control will work for the 919? It is not on thier list of "approved bikes". A call to them did no good. Person I spoke to had never heard of a 919.
I have the BrakeAway from a previous bike. Great product, well made. Would love to use it on my 919.
I'll never understand why all these companies call their products Cruise Controls when they can't 'control' the speed. They're throttle locks. My friend bought a similar product and said he liked that he could take his hand off the throttle when he needed to, but for a 'cruise control' it didn't work nearly as good as his car. "The bike speeds up going down hills and slows down going up hills. My speed varied by almost 40 mph... "
I almost fell over laughing.
Yep...they dont do very well controlling speed, but being able to take your right hand off the controls for just a minute is well worth the $20 or so that a decent (and decently priced) throttle lock will cost you.
I agree! I don't have one, but many times on long rides I wish I could take my hand off the throttle for a few seconds to shake out the stiffness.
i have a throttle lock on my bike and its nice... the ammount of throttle the 919 needs to go down the freeway is almost nill and its nice just to lock the throttle so you dont have to constantly grip the throttle... ill lock it but still keep my hand on the throttle and make minor adjustments as needed... but the rest of the time i ever so lightly grip the throttle... just as if it was my left hand... just lightly gripping holding on. its nice for the longer trips.
but yes up and downhill will obviously be effected as more or less throttle is needed... but for less than 20 bucks its well worth it.
To the OP, And I'm not entirely sure about this because I don't know much about that throttle lock, but I don't think it'll work, size wise.
All the honda bikes they are listed are cruisers, cruisers have 1 inch grips and the 919 has 7/8 inch grips does it not?
Maybe someone else can correct me on this?
Thanks to all who tried to answer my question. I got the BrakeAway installed last night. Works great. The 919 has 7/8" grips from the factory, but luckily I had aftermarket grips which made the grips 1".
Although not cheap, the BrakeAway is a great device for holding the throttle at a set position while you are riding. Yes, it is not a real cruise control, but it does allow you to take your hand off the throttle for a while. Very nice when you are on a flat highway for a while.
The advantage of the BrakeAway is that it will automatically disengage as soon as you pull the front brake lever. Saves a precious second or two in an emergency situation.
Great device, well made, recommended. A little tricky to install, but if you take your time and think about what the instructions are telling you and look at the device, anyone can do it.
I have a Throttlemeister on my FJR, works great on long trips, but as previously mentioned, only good for flat roads. Definitely a plus to be able to uncramp your hand and shake out the numbness though. I've used the Crampbuster before as well, allows you to straight our your fingers while keeping a constant throttle pressure, can't beat if for a cheapo quick fix.
Glad to hear the review on the BrakeAway, have researched those before and seems like a high quality product.
1 - 11 of 11 Posts
