Just want to put out a feeler concerning power commanders; I have a 2002 919 that I've been working on and would like to know if anyone knows of a tuner better suited for this bike than the pcIII power commander.
I'm not sure what you mean by "better suited", seeing as a PCIII is a very effective unit on a 919.Just want to put out a feeler concerning power commanders; I have a 2002 919 that I've been working on and would like to know if anyone knows of a tuner better suited for this bike than the pcIII power commander.
I think that this is related to this thread
http://www.wristtwisters.com/f322/dobeck-performance-29268.html
Different IP's.i was thinking the same thing!
DEV - DEVONDUNIT.....????
COINCIDENCE???
first post..i'm not buying it
calling goog3le...same guy???
Exhaust O2 feedback loop driven Autotune will never replace high performance mapping by a tuner, because it is counter to it.you could try the power commander V. I called dynojet one day. They said that you could put the pcV on a 919. They just don't offically endorse it since the 919 is no longer being manufactured. Then you just use a 919 map.
or.....
If you're really good, or have enough money, you could install an o2 sensor into the exhaust and get the auto tune module. That would be sweet. It adjusts everything on the fly.
Had I known this before i bought my PCIII new, I would have been the guinea pig
So there is a distinct choice to be made, and both are valid depending on one's intent.
Autotune is a great device if all you want is a nominal 14:1 right across the board while also being environmentally sensitive by reduced unburned HydroCarbons and CO(carbon monoxide), while sacrificing some potential torque and power.
I'd also think that an O2 sensor from some other Honda could fairly easily be grafted to the header of a 919, and allow a PC V to do Autotune on a 919, should anyone want to do that. It would be a good question to put to Power Commander.
I don't know these devices, but have heard they do come with user adjustability etc, and what you note above sounds consistent with all that.Not necessarily true. You can have it that way. Like set it and forget it. But if you want to have pre set settings in certain rmps, or throttle position, or even certain gears you can do that. (for the gears you would need the quick shift kit just so it knows what gear you are in.)
Thats what I've been told. maybe I'm wrong.
edit you can also set auto tune to kick in only when the engine is above certain temperatures
I've often wondered about some of the side mount conversions I've seen here, in terms of grinding out the piping that is.Nice! One question...do you ever touch down the peg on the right side or the pipe? I'm thining about a similar location for my side pipe, but it's a DanMoto JISU carbon trioval design. Figure I can angle the flat part for max clearence... I' diggin the orange! Same color braided lines would look sick!
-Jonny
-Jonny
I'm no crazy rider, but I've touched down pegs on both sides and never got close to my setup.I've often wondered about some of the side mount conversions I've seen here, in terms of grinding out the piping that is.
There's a number running them, someone will surely chime in and pass on their experience in this regard.
A stock suspended 919 can very easily grind the pegs with the feelers off.
IF you do track days, and are stock suspended (o4 and later in particular) and have some level of proficiency, you'll be folding your pegs routinely and looking for a way to keep your boots from getting chewed to bits.
<<<<< see avatar pic.....
haha, and then helmet, shoulder, knees, elbows and face?I've ridden with a 919 owner that touched down his feelers followed by his bar ends and his OEM exhaust.
That DOES conjure up a certain image ....................I've ridden with a 919 owner that touched down his feelers followed by his bar ends and his OEM exhaust.
