Hey guys, I've got a few issues with my '05 919, it's completely stock except for some delkevic slip-ons. Also just to note these problems were present with the stock mufflers.
Firstly, the bike rides/idles fine when cold/warming up, when it reaches temp the idle starts to get pretty rough, it climbs then drops, and vice versa. It drops a good 3-400 rpm then evens out periodically, then continues fluctuating. It sounds and feels awful.
Secondly, when riding the bike warm it tends to stumble/lurch/backfire, for instance when holding the throttle to keep a steady speed it lurches and stumbles, occasionally backfires, it's never a comfortable ride as you're being jerked around in your seat. Acceleration is not consistent, it hesitates, stumbles and backfires. Deceleration causes backfiring.
Finally, the bike cuts out while riding, usually the lurching/stumbling worsens and the bike just shuts off. FI light comes on, ignition does nothing, all other electrics work. Switching the key off and on fixes it. It's not a uniform, predictable issue, it could happen 2 minutes down the road, or an hour.
The first time the bike switched off on me it was raining, I was only 2 minutes down the road, I came to a stop and the HISS light flickered along with a relay of some sort rather quickly, that stopped, I tried to start it but the ignition did nothing, no crank. So I switched the key off and on and continued, bike started fine. It died again after another few minutes of riding, conveniently as I came into the driveway...
If anyone can shed some light on what might be the issue I'd be very grateful!
Cheers guys
Cheers guys
