Come back in 20,000 miles.my 04' 919 is showing 17,562 kms.
As a general rule valves get tighter as they wear, so assuming you tested the compression correctly it should only be a function of ring/cylinder sealing, and have nothing to do with valves unless one is bent or something is majorly wrong.Bought my 04 with 37k on it, already about to hit 40k soon. Bike runs fantastic. It was basically stock when I got it. I added danmoto slip ons and a PC3 and it runs even better. Out of curiousity I checked the compression when I pulled the plugs. Average was about 160ish. Not sure if the valves need adjusting because the book calls for 185psi.
Doesn't that in turn make the valve stay open longer than it's needed?As a general rule valves get tighter as they wear, so assuming you tested the compression correctly it should only be a function of ring/cylinder sealing, and have nothing to do with valves unless one is bent or something is majorly wrong.Bought my 04 with 37k on it, already about to hit 40k soon. Bike runs fantastic. It was basically stock when I got it. I added danmoto slip ons and a PC3 and it runs even better. Out of curiousity I checked the compression when I pulled the plugs. Average was about 160ish. Not sure if the valves need adjusting because the book calls for 185psi.
Nice! What windscreen and luggage system is that? Looks like a nice set up for long distance =)Only 79K on the '03 so far and it runs like a top.
Thanks! It is a Givi System with three E36 cases and a Memphis Shades Bladerunner. Unfortunately, the bags, racks, and shield are no longer available.Nice! What windscreen and luggage system is that? Looks like a nice set up for long distance =)
All sounds pretty normal. Many, many miles left if you take are of her.I bought my 919 in summer 2017 with 15000 miles on it. I paid 3700$. After I bought it I replaced tires and rear brake pads and air filter. Rode all season. Later I bought new chain and sprockets. Fresh coolant and brake fluid. Ended season with about 25000 miles. Season 2018 - I put like 11000 miles on it so I am at little over 35000 miles. Bike still runs like a champ. Rear bearing on brake side took a crap at 35000 so I replaced all bearings. Bike will need valve clearances inspection soon but other than that it just keeps going. Maybe spark plugs next spring... I go with honda full synthetic oil, I have like 10000 miles on it. Time to change next season lol. I went thru one front pilot 3 tire and 3 rear ones. Now I switched to pilot 4. First front one and second rear tire... I am planning to keep this bike for one more season, maybe 2. It is well balanced motorcycle, and it takes 87 octane gas. I don't see any difference when running on premium gas mileage wise or power wise...
What would you consider to be "taking care of her?" My bike just hit 50k miles. I'm pretty sure the valve guides or seals are on their way out.All sounds pretty normal. Many, many miles left if you take are of her.
