WristTwisters.com banner
1 - 1 of 1 Posts
My question is on my V30 (VF500C) I am having a problem with the clutch. I have rebuilt both the Master cylinder and Slave cylinder but still have no clutch disengage when I squeeze clutch lever. There isnt much resistance on the clutch lever and I have bleed the system several times. I removed the slave cylinder and it seems like the rod running from the slave cylinder to the clutch assembly is not functioning properly. The rod seems to slide toward the clutch assembly and then bottom out I tried to push the rod inward further but will not go any further. Is it possible that when the rod was removed from the slave cylinder side something on the clutch side either fell off or dislodged?
1 - 1 of 1 Posts
