1 - 3 of 3 Posts
:hello:
btw, once you remove the spring, don't let go to the cartridge rod, tie a wire to it or something before you let it go. If you let it go, it will just sink inside and you will need to take forks out as the lower triple won't let you raise the bottom leg far enough so you could reach that rod
Thanks! After my warranty is up(over next winter) I'm thinking of doing some susp work, I need to recover from recent spending sprees. I think I'll improve greatly with new springs and shock, I have three Givi cases on the back and I'm probably 240 with gear. Still playing with preload setings, havn't touched rebound yet.
are you talking about the front?
if so, there is no need to play with stock forks as they are way out of your weight range. Crank that preload all the way in and put rebound 2.5 turns out from full in.
I wouldn't wait for the warranty and at least do the min - put 1kg springs in the front. Being 240lbs you will see a drastic difference from the stock, it will be just like new bike. It will be the best $100 you can spend on your 919.
BTW, warranty on 919, especially extended warranty is the biggest scam going IMO, they just don't brake. I've yet to see anyone with 919 who claimed a manufacturing defect
Thanks for the tip, I'll do that tomorrow, I did set preload two more notches and that made a world of difference. I plan on springs(possibly in the near future). What would you recomend for the rear, currently I have preload @3and havn't touched rebound yet. What brand of springs is good?( Racethch, Ohlins?) I think I'm going to save my pennies for Ohlins rear shock over the winer.
1 - 3 of 3 Posts
