How do i get XR100 tires off the rims?? - Wrist Twisters
post #1 of 7 Old 12-21-2007, 06:00 AM Thread Starter
so i got new tires and tubes, but cant get the tire off the rim for the life of me...
any suggestions tips how to's are appreciated...
heavyzee is offline
post #2 of 7 Old 12-21-2007, 06:04 AM
Just break the bead and work your way around the rim, it's actually very simple.
dadogs is offline
post #3 of 7 Old 12-21-2007, 06:06 AM
Is there something unusual to the problem?
I use 3 tire levers and they just pop off. Make sure the bead on the opposite side of the rim stays off the rim bead and it should be easy peasy.
post #4 of 7 Old 12-21-2007, 06:11 AM
You can refer to this well documented article. Obviously some of the steps do not apply but it will show you how to pry the tire off the rim. Most important is the tube. Be extra careful when removing/installing it.
post #5 of 7 Old 12-21-2007, 06:39 AM
Really can't add anything to what has already been said. Worst case ... use a SawZ-All,
RC51_CBRXX is offline
post #6 of 7 Old 12-21-2007, 06:47 AM
You could always burn it off. Just wear a face mask, as that black smoke will make you pretty loopy.
post #7 of 7 Old 12-21-2007, 07:40 AM
make sure you loosen the bead lock
bionicman is offline
