bike weight reduction plan! - Wrist Twisters
post #1 of 22 Old 09-18-2008, 05:06 PM Thread Starter
I might have gone too far removing excess weight?
post #2 of 22 Old 09-18-2008, 05:08 PM
Good work! Now put some helium in the tires and get ridin'
post #3 of 22 Old 09-18-2008, 05:14 PM
It's gonna be loud, and probably run a little lean.
post #4 of 22 Old 09-18-2008, 05:31 PM
C'est la vie
CMulford's Avatar
Nah, just hit the fast forward button on the remote exiting corners and you're golden!
CMulford is offline
post #5 of 22 Old 09-18-2008, 05:44 PM
Just push the "Easy" button!
Are you going big bore? I assume not since the piston still resides on the rod. But man, just think of the added TQ with the BB Kit!!! Not that a 525 is a slouch but more is better! Right?
I think we should all vote on it!
Big Bore or Not??? I say big bore since there is no added labor from where you currently are on the Teardown, other than removing the wrist pin from the piston and installing the new one, I mean High Compression Hammer!
Squeeze it tight before you light!!!
Ripper is offline
post #6 of 22 Old 09-18-2008, 05:59 PM
Now wedge that sucker in the 150 frame and show 'em what you really got!
post #7 of 22 Old 09-18-2008, 06:06 PM
You can never be too light or have too much HP!
post #8 of 22 Old 09-18-2008, 07:52 PM
Tirone is my middle name
mattf's Avatar
I say put some big tires on it with more air volumn, then mount that big fan on the back and take it to the florida swamps. show those air boat guys a thing or two.
you could replace that chain with a heavy duty zip tie to loose a little more weight...
mattf is offline
post #9 of 22 Old 09-18-2008, 08:06 PM
why did you leave the front tire and forks on? you can just take them off and save even more weight by only riding on the rear tire.
post #10 of 22 Old 09-18-2008, 08:11 PM
ajcombs's Avatar
Helping a Member in Need
I think something important is missing not sure what though.
I vote big bore!!!!
ajcombs is offline
post #11 of 22 Old 09-19-2008, 03:52 AM
Big bore will only increase the weight...will give the bike more balls tho
post #12 of 22 Old 09-19-2008, 03:54 AM Thread Starter
I like the big bore idea, next time it explodes I'll do it for sure!
post #13 of 22 Old 09-19-2008, 03:55 AM
Funny Guy!
Ripper is offline
post #14 of 22 Old 09-19-2008, 06:36 AM
Push it to the top of the tallest FL hill and claim you are the coaster race King!
dream is offline
post #15 of 22 Old 09-19-2008, 06:47 AM
"Whose ABBA ZABBA?"
I'd say that piston is as light as it will get, so you can put the motor back together and look elsewhere for weight savings.
It looks like an aluminum lolipop.
General George S. Patton
post #16 of 22 Old 09-19-2008, 07:57 AM Thread Starter
That would be this anthill I have in the back yard. It's not big but they sure are industrious and ambitious.
I thought the same thing, it tasted awful.
post #17 of 22 Old 09-19-2008, 09:37 AM
Is it just me, or did you take the timing chain apart?
The setup looks an awful lot like the honda 450 motor, so with that said I've taken them apart more than I care to have and never done that? KTM could, or I should say "is" knowing KTM's different approach, doing things differently to easy in servicing?
Please fill me in? I've been thinking of picking up a KTM 525 quad and its serviceability is something I like to know about. That sure would make top end servicing a piece of cake!
Oh, is the head ported? If not are you going to?
Ripper is offline
post #18 of 22 Old 09-19-2008, 10:58 AM Thread Starter
See the attached picture, you can see where the cam chain passes through either side of the head but it's solid in the middle so to remove the head you must break the timing chain on the 525. There's no clip so you must grind the pins down and replace the link.
So far it's shown to be an easy bike to work on but I cannot, as of yet, say it's been perfectly reliable.
I'm not doing any porting or polishing, time isn't on my side for this repair so I just need it running.
post #19 of 22 Old 09-19-2008, 12:37 PM
1000RRHooligan's Avatar
Outstanding Restoration
I have a chain tool if you need it. For breaking chains, pressing in clips and side plates, and riveting the link.
Low Post Whore!
1000RRHooligan is offline
post #20 of 22 Old 09-19-2008, 12:38 PM Thread Starter
that might be useful. unless you're thinking of the chain tool you own that's in my toolbox already.
post #21 of 22 Old 09-19-2008, 02:44 PM
Huh? Do I own two of them?
I did think I had a different one when I was putting the chain on the RVF. I was looking for it and found this other one and thought it looked different. I did the same thing with tire irons and Cil. I called and said "you got the other set of tire irons?" Turns out he did have them. Must be losing my mind.
Low Post Whore!
post #22 of 22 Old 09-19-2008, 03:43 PM
I see. That is messed up, IMO. for in the field repairs that just wouldn't float!
the honda head allows for removal without breaking the chain.
Ripper is offline
