BBR spring issues CRF100F - Wrist Twisters
post #1 of 9 Old 07-23-2007, 11:12 AM Thread Starter
so i put these springs in supposted to be 30% stiffer and swapped the front tire to a 16"
now the front end bottoms out like crazy in the dirt....
i havent touched the fork oil yet, but any one have any ideas??
heavyzee is offline
post #2 of 9 Old 07-23-2007, 11:17 AM
why go to a 16" front? you doing something way cool to this bike? minisupermoto?
did you change anything else when swapping springs? Are you sure you got the correct springs, compare them to the originals when you had them removed?
post #3 of 9 Old 07-23-2007, 11:23 AM Thread Starter
mini supermoto is the plan, as it's every friday night at Moroso on the go-cart track for $25 4 hours all u can ride... from what i have read on supermotojunkie.com the bridgestone BT-045 on the 16" wheels is the way to go, unless u have mad $$ to spend on excel 17" wheels
i'll take some pix of the springs side by side, but the BBR's are prolly 1/2 inch longer, and def. thinker guage steel...
heavyzee is offline
post #4 of 9 Old 07-23-2007, 11:36 AM
excellent - please post some pictures of the finished product. Excited to see it come together for you.
If they're the right springs I can think of no reason it'd be bottoming out. Seals in tact? not blowing oil everywhere on compression? very odd. Mine were noticeably stiffer just riding down the street. I did add a bit of oil but only a couple millimeters per leg.
post #5 of 9 Old 07-24-2007, 07:22 AM
You should change the oil out to a 15W as well. It works in perfect combination with the new stiffer springs. Greatly enhanced the fedback from the 125. I plan on racing SEMRA with it next year. New SM wheels-n-tires are $356 mounted for 17" front and rear.
post #6 of 9 Old 07-24-2007, 07:33 AM
hmmmmm.... from where please?
post #7 of 9 Old 07-24-2007, 07:34 AM
I'll send you the link via PM.
post #8 of 9 Old 07-26-2007, 10:34 PM Thread Starter
BBR springs vs. stock
also i stripped and repainted the forks, polished the fork tubes, and painted the lower triple
drained the fork oil... don't think it's supposted to look like this... will replace with 15w
there was exactly the same amount in each fork tube, so... they are either leaking evenly, or not leaking at all....
heavyzee is offline
post #9 of 9 Old 07-27-2007, 01:06 PM Thread Starter
ok i got the 15w fork oil, now just need to know how much to put in...
heavyzee is offline
