What do you think ? - Wrist Twisters
post #1 of 5 Old 09-15-2012, 10:13 AM Thread Starter
FXS
Knees in the Breeze
FXS's Avatar
What do you think ?
Friend just bought an '85 Gold Wing Aspencade Bikes ~95% Good rubber Dry frame, Drive line. needs a little TLC. 26K on Speedo...$2000
Never pick a fight with an old man..if he's too tired to fight, he'll just shoot you.
1979 H-D Low Rider (orig owner)
2009 K 1300 S (Lava Orange...the faster color)
FXS is offline
post #2 of 5 Old 09-15-2012, 10:28 AM
undercover919's Avatar
sounds like a fairly good deal to me
2003 Honda 919
undercover919 is offline
post #3 of 5 Old 09-15-2012, 11:41 AM
Pics?
post #4 of 5 Old 09-15-2012, 11:51 AM
Serial Monogamist
ST-DocLizard1's Avatar
Total Awards: 21
The '84-'87 GL1200 series has been prone to stator failures. Check stator output and continuity between the three phases. Look for corrosion at the stator, R/R, and starter solenoid connections. Some of the 1200 series have had their stators replaced by Honda and/or hardwired instead of the dreaded plastic plugs which are prone to corrosion and meltdown backing the heat up into the stator. In order to replace the stator, the engine will need to be removed from the frame. Last time I heard, it was $1,000 to change the stator at the dealer.
IIRC, the Aspencade model has the LCD dash/guages which could be problematic and difficult to repair/replace. The same goes for the Type III radio system.
Otherwise, the GL's are bulletproof.
I own an '81 Interstate and an '82 standard.
Both are the GL1100 series('80-'83)
Unless it is in absolute pristine shape, 2K seems a little steep to me regardless of the mileage. Showroom quality specimens go for $2,500 to $3,000 and I'm talking trophy winners.
Doc
ST-DocLizard1 is offline
post #5 of 5 Old 09-15-2012, 01:29 PM Thread Starter
FXS
Knees in the Breeze
FXS's Avatar
Thanks for the input as i know squat about older metric cruisers. She's not a show stopper but is clean , no evidence that i could find that its been dropped. There is some re-wireing that was done on port side of engine , but i haven't traced them to tell where they go. Starts right up, runs smooth. Just put new battery in, going to test alt output and go for a test ride.
FXS is offline
