Magna no spark - Wrist Twisters
post #1 of 8 Old 04-04-2015, 03:07 PM Thread Starter
02 919
Death Barrel's Avatar
Magna no spark
I have a 2000 vf750 magna with intermittent spark on front right cylinder no the plug. Wires have close to same resistance. One box per front cylinders. Does anyone have any idea what I can look for.
Death Barrel is offline
post #2 of 8 Old 04-04-2015, 06:11 PM
Test your battery.
post #3 of 8 Old 04-05-2015, 09:09 AM
+1. Yeahh just changed the battery on my grill igniter. Sparks great now.
post #4 of 8 Old 04-05-2015, 09:17 AM
Nickr919's Avatar
Loose wires to the coil, cracked wire on the spark plug wire. Intermittent spark in my experience is a bad connection somewhere in the wiring.
Nickr919 is offline
post #5 of 8 Old 04-05-2015, 06:15 PM
3dcycle's Avatar
if I remember correctly there are 2 coils on that bike, 1 coil=2 spark plugs check the other 3 if they spark good not the coil, or anything before coil. would have to be plug wire or boot or even spark plug.
and counting
3dcycle is offline
post #6 of 8 Old 04-08-2015, 03:53 PM Thread Starter
02 919
Replaced wires and coil on front. No fix. I read that the drain screws on the bowls must point towards center of the bike.(backwards) or a lean condition will occur.( mine are out) Runs good on choke. With no choke I get a big backfire in the pipe every couple strokes.
post #7 of 8 Old 04-08-2015, 05:27 PM
3dcycle's Avatar
the carbs wont affect spark, get the spark fixed before jumping to something else. I assume that you did in fact check for spark at the plug and confirmed it does not have spark.
and counting
3dcycle is offline
post #8 of 8 Old 04-08-2015, 05:35 PM Thread Starter
02 919
I was getting shock pretty good so. Only thing I can think of is the boot is arcing to head. And I replaced it
