2008 Honda Interceptor - Wrist Twisters
post #1 of 12 Old 09-05-2007, 09:39 PM Thread Starter
Official picture from Honda
post #2 of 12 Old 09-05-2007, 09:49 PM
Toll Runner
str8ghtjacket's Avatar
Wth, boring. Great bike why dont they do something different, seems like they could come up with something better than that.Solid blk with some light wht pinstripes here and there, I dunno something, str8
str8ghtjacket is offline
post #3 of 12 Old 09-05-2007, 09:51 PM Thread Starter
Interceptor/Interceptor ABS
The quintessential sport touring motorcycle for sport bike riders, the Interceptor stands far above all others thanks to its exemplary handling, high-performance VTEC engine, all-day comfort and long-range amenities. Offered in Metallic Silver.
Interceptor MSRP: $10,799
Interceptor ABS MSRP: $11,799
I was really hoping to see a V5 in this thing.
post #4 of 12 Old 09-05-2007, 09:52 PM Thread Starter
09/05/2007 - Torrance, Calif. - Model: VFR800FI / VFR800FI ABS Engine Type: 781cc liquid-cooled 90° V-4 Bore and Stroke: 72mm x 48mm Compression Ratio: 11.6:1 Valve Train: VTEC DOHC; four valves per cylinder Induction: PGM-FI with automatic enricher circuit, 36mm throttle bodies, and 12-hole injectors Ignition: Computer-controlled digital with three-dimensional mapping and electronic advance Transmission: Close-ratio six-speed Final Drive: #530 O-ring chain Suspension Front: 43mm HMAS cartridge fork with spring preload adjustability; 4.3 inches travel
Rear: Pro Arm single-side swingarm with Pro-Link single HMAS gas-charged shock with seven-position spring preload and rebound damping adjustability; 4.7 inches travel Brakes Front: Dual full-floating 296mm discs with LBS three-piston calipers
Rear: Single 256mm disc with LBS three-piston caliper; Optional ABS Tires Front: 120/70ZR-17 radial
Rear: 180/55ZR-17 radial Wheelbase: 57.4 inches Rake (Caster Angle): 25.3° Trail: 100mm (3.9 inches) Seat Height: 31.7 inches Fuel Capacity: 5.8 gallons, including 0.8-gallon reserve Color: Metallic Silver Curb Weight*: 540 pounds
551 pounds w/ABS *Includes all standard equipment, required fluids and full tank of fuel--ready to ride.
Meets current CARB and EPA standards.
post #5 of 12 Old 09-05-2007, 10:08 PM Thread Starter
09/05/2007 - Torrance, Calif. - For sport touring with an emphasis on Sport, the Interceptor continues to stand far above all others thanks to its exemplary handling, high-performance VTEC engine and long-range amenities.
Features & Benefits
New for 2008
  • New Metallic Silver color
Unique features
  • Revolutionary VTEC combines the power characteristics of both two- and four-valve cylinder-head designs. The engine runs on two valves per cylinder below 6400 rpm then switches to four valves per cylinder to deliver significantly stronger low-end and mid-range torque, while maintaining the Interceptor's impressive high-rpm power delivery.
  • Programmed fuel injection (PGM-FI) (see Technology Section).
  • Unique Pro Arm® Rear Suspension (see Technology Section)
  • Pro-Link Rear Suspension (see Technology Section)
  • Unique NR-style center-up exhaust system incorporates two stainless steel mufflers tucked beneath the Interceptor's tail section.
  • Large-diameter 43mm Honda Multi-Action System (HMAS) cartridge front fork provides enhanced handling under all riding conditions.
  • Linked Braking System (LBS™) (see Technology Section)
  • Anti-Lock Braking System (ABS) model available (see Technology Section).
  • Four brilliant multi-reflector headlights employ two centrally positioned H4 low/high beams positioned under two widely spaced H7 high beams for brilliant nighttime illumination.
Engine/Drivetrain
  • Compact 781cc DOHC 90-degree V-4 with an oversquare bore and stroke of 72mm x 48mm.
  • Silent-type cam-chain drive eliminates mechanical gear noise. The system features a set of dual tensioners that maintain optimal pressure and lubrication for the camshaft chains, ensuring quiet operation and long life.
  • Iridium-tip spark plugs are ignited by compact high-energy coil-on-plug spark plug caps that produce a strong, high-voltage spark.
  • Interceptor engine serves as a stressed member of the pivotless frame, which features specially designed engine mounting bolts tuned to work in harmony with the damping characteristics of the frame.
  • Aluminum-composite cylinder sleeves are high-pressure-formed from sintered-aluminum powder impregnated with ceramic and graphite. The composite sleeves provide better wear resistance and superior heat dissipation than conventional sleeves.
  • Cast-aluminum pistons feature LUB-Coat solid lubricant to minimize friction between piston and cylinder wall.
  • Auto-enriching system is integrated into PGM-FI module, which optimizes the air/fuel mixture on cold starts and eliminates the need for a manual choke.
  • Solenoid-operated dual air-intake duct design keeps one duct closed during low-speed operation to ensure optimal control of air-intake velocity.
  • Dual side-mounted radiators maximize cooling efficiency using low-air-pressure areas created by side cowls to draw cooling air through the radiators. During low-speed operation, a thermostat-controlled left-side fan pulls cooling air across the radiator into the fairing to keep hot air away from the rider.
  • Rugged 125mm-diameter eight-plate clutch offers light weight and high load capacity.
  • Clutch features an offset outside friction plate for quiet operation when starting from a stop.
  • Exceptionally smooth-shifting six-speed transmission.
  • Three-phase coil-spring damper in the transmission provides for seamless upshifts.
Chassis/Suspension
  • Triple-box-section twin-spar aluminum frame features a tuned, pivotless design that isolates the engine-mounted swingarm from the frame and contributes to handling comfort.
  • Unique Pro Arm® Rear Suspension (see Technology Section).
  • Pro-Link Rear Suspension (see Technology Section).
  • Linked Braking System (LBS™) (see Technology Section).
  • The Interceptor's 296mm floating front-brake discs feature a lightweight seven-spoke inner rotor design.
  • U-section cast-aluminum wheels are light and reduce unsprung weight.
  • The six-spoke, 3.5-inch-wide front wheel carries a 120/70ZR-17 radial tire. The five-spoke, 5.5-inch rear wheel sports a wide, low-profile 180/55ZR-17 radial tire.
Additional Features
  • 5.8-gallon fuel capacity for excellent sport-touring range.
  • The Interceptor's sleek, aerodynamic bodywork is functional and beautiful.
  • Satin-finish treatment on muffler covers and exhaust heat shield for distinctive styling.
  • Stylish silver finish on clutch and brake master cylinders.
  • Clear turn-signal lenses front and rear provide a high-tech look.
  • Air flowing through the windscreen's central air vent provides cool air to the rider at low speeds and increases rider comfort at higher speeds.
  • High-tech instrument display includes electronic tachometer, LCD readouts for speedometer, air temperature, coolant temperature, odometer, two tripmeters and clock.
  • ACG output of 497 watts.
  • Detachable seat provides storage for a U-lock and other necessities. (Lock not included.)
  • Removable passenger seat cowl.
  • Adjustable brake and clutch levers.
  • Injection-molded nylon passenger grabrails are comfortable to the touch in cold or hot weather.
  • Folding aerodynamic mirrors.
  • Transferable one-year, unlimited-mileage limited warranty; extended coverage available with a Honda Protection Plan.
  • Purchase of a new, previously unregistered Honda USA-certified unit by an individual retail user in the United States qualifies the owner for a one-year complimentary membership in the Honda Rider's Club of America® (HRCA&#174. Visit www.hrca.honda.com for details.
Available Honda Genuine Accessories
  • Touring Accessories: Color-Matched Hard Saddlebags, Sport Touring Trunk, Saddlebag Liner Set, Trunk Liner.
post #6 of 12 Old 09-06-2007, 06:49 AM
Ken
Community Admin
Ken's Avatar
Looks like the ST1300 without side bags. They are going to have a harder time differentiating the two. Not unlike the crossover problem they had with the Valkyrie/ST13/Wing a few years back. And that's when the Valkyrie was dropped from the line-up. That big 6 was an awesome motor on that frame.
2009 Honda Goldwing
Ken is offline
post #7 of 12 Old 09-06-2007, 06:53 AM Thread Starter
I've tried hard to fall in love with the VFR Interceptor but it still remains nothing more than a weekend fling.
A V5 might've brought me to the alter.
post #8 of 12 Old 09-06-2007, 06:58 AM
async's Avatar
Looks the same as the old model. It's turning into Honda's version of the Concours.
async is offline
post #9 of 12 Old 09-06-2007, 08:05 AM
The twister is quickly becoming a place of: Reasons to not buy a honda.
Lemonhead is offline
post #10 of 12 Old 09-06-2007, 08:13 AM Thread Starter
one of the advantages of being manufacturer agnostic.
post #11 of 12 Old 09-26-2007, 10:45 AM
I've been looking at bikes a lot lately, and the Viffer is on my short list. Anyone know if they've solved the electrical problems (rectifier in particular)?
MrJP is offline
post #12 of 12 Old 09-26-2007, 10:52 AM
The rectifier problem was on the older generation VFR's. I would hope Honda has rectified(no pun intended) the problem by now.
