Replacing Clutch Plates on 74' CB 750 - Wrist Twisters
post #1 of 5 Old 04-07-2007, 10:53 AM Thread Starter
Pudendal
919MN's Avatar
Has anyone replaced the clutch plates in a K series 750. I am thinking of replacing the ones in my 74' as i tend to get a little clutch slip if i roll on it too hard. I was wondering how difficult it is and if it will require me to remove the motor from the frame. thanks.
919MN is offline
post #2 of 5 Old 04-07-2007, 11:16 AM
Ah.. a motor I can relate to! Before you get to deep into replacement discs/plates, be sure the clutch is properly adjusted. Do you know how to preform this adjustment? It is more than a simple cable free play adjustment.
post #3 of 5 Old 04-07-2007, 06:15 PM Thread Starter
Pudendal
919MN's Avatar
is it something that would be in the clymer manual?
919MN is offline
post #4 of 5 Old 04-07-2007, 06:46 PM
Never had a Clymer manual! It is spelled out in the CB750 Honda shop manual. Clymer's might have a step-by-step.
Try this:
Loosen the lower cable adjuster, set the handlbar cable adjuster at it's mid-point. Don't worry about free play at this point, it's the last step.
On the right side cover you will see a small cover with a arge slot. Using the shock spanner from your toolkit (or a half dollar), remove the cover.
You will see a small nut and screw arrangement in the center of the hole. While holding the screw from turning, loosen the nut 2 turns. Now, while holding the nut, turn the screw in until it stops. Back out one full turn. While holding the screw, tighten the nut. Make sure the o-ring on the cover is clean, and put it on. Take the slack out of the clutch cable at the lower adjuster. Adjust free play [0.25"-0.50"] at the handlebar.
The way it works: The screw adjusts the clutch spring pressure, in is more, out is less. The nut is a locking device.
post #5 of 5 Old 04-07-2007, 11:48 PM
ajcombs's Avatar
Helping a Member in Need
awesome Mike !! Sounds like you had a few of these.
ajcombs is offline
