Woodyee, li'l help? - Wrist Twisters
post #1 of 4 Old 02-02-2010, 10:29 AM Thread Starter
bucky's Avatar
Woodyee, li'l help?
not to denigrate CBRracer77, but seeing as Woodyee is probably staring at his...a little clarification or at least a second opinion might be called for. i posted in the wrong thread earlier:
upon disassembly of the case halves the two oil orifices fell out. one of them is lost. i have both on order, but the shop manual and online fiches aren't very clear to which goes where, and what orientation they'd have beyond, "aligning their cutout with the groove in the upper crankcase".
anyone have good pix of correct location/orientation of these two separate part numbers? or at least a better description than the factory gives me?
bucky is offline
post #2 of 4 Old 02-02-2010, 11:48 AM
woodyeee's Avatar
Here you go Bucky........these are in the bottom crankcase as i have taken them off the top case so its ready for a rebore when the pistons arrive.
One of these little critters will only fit one way as there is a flat side that fits into the top crankcase.
The other one thats nearest the clutch side can fit both ways, it looks as though it just feeds oil to the bearing nearest the clutch basket.
Hope this helps.
Where is the other thread?
woodyeee is offline
post #3 of 4 Old 02-02-2010, 04:08 PM
Here:
https://wristtwisters.com/open-bike-d...internals.html
post #4 of 4 Old 02-03-2010, 11:41 AM Thread Starter
bucky's Avatar
to quote Sweet Polly Purebread, "MY HERO !"
thanks Wood.
alas, they're on backorder. i'll just be plastigaging for now i guess.
bucky is offline
