without a centerstand - Wrist Twisters
post #1 of 36 Old 12-10-2006, 01:01 PM Thread Starter
wisco919's Avatar
Is there anyone out there that may know where to locate spindles and track stands to work on a 919 without a centerstand. i.e. change tires, sprockets, and chain. Any info on how or where to find stands or get around using them would be great.
wisco919 is offline
post #2 of 36 Old 12-10-2006, 01:12 PM
BockHawk's Avatar
Pit Bull makes good stands. Don't get spindle style stands, though, since the 919 doesn't have mounting points for spindles unless you're handy with a welding torch.
2002 919 40,000 miles
BockHawk is offline
post #3 of 36 Old 12-10-2006, 01:14 PM
+1 Pit-Bull
post #4 of 36 Old 12-10-2006, 06:31 PM Thread Starter
wisco919's Avatar
The front stand is lifting againts the head assembly? Where to purchase? Are they bike specific?
wisco919 is offline
post #5 of 36 Old 12-10-2006, 08:05 PM
I've got both PitBull and centerstand. If I had to choose twix the 2, I'd go with the centerstand. Once on the centerstand, the bike is nearly balanced, so to get the front off the ground, just hook a tie down strap onto an overhead rafter.
post #6 of 36 Old 12-11-2006, 05:48 AM
ajcombs's Avatar
Helping a Member in Need
that's a good idea but can you get both front and rear off the ground at the same time?
ajcombs is offline
post #7 of 36 Old 12-11-2006, 06:51 AM
Unbannable
Super Sneaky Steve's Avatar
Does anyone know if the exhaust has to come off to put an Honda brand center stand on?
Super Sneaky Steve is offline
post #8 of 36 Old 12-11-2006, 07:01 AM
Yup... Unless you use the stand modified by MotoCycho.
post #9 of 36 Old 12-11-2006, 07:52 AM
With wheels and tires on, the front end held up by a tie down, yes both would be about an inch off the ground. If you need a little more room, you can put a board under the centerstand, but then you might need a buddy to help you get it up. Obviously with the rear wheel off, you'd have all kinds of room.
If modifying a Honda centerstand, or removing part of the exhaust doesn't set well with you, there is a German out fit that makes one that goes right on with no extra work. I saw it on a link that someone here posted, I just cant remember where right now...
post #10 of 36 Old 12-11-2006, 09:46 AM
Here's a link to a center stand that does not require removal of the exhaust system to install.
http://www.twistedthrottle.com/trade...tview/299/197/
JAX'9er is offline
post #11 of 36 Old 12-11-2006, 10:19 AM
Unbannable
Thanks! I'm getting that one ASAP!
post #12 of 36 Old 12-11-2006, 11:48 AM
Richr8
Guest
Posts: n/a
The Honda unit...
...is on my Christmas list. If, I get it, I'm going to mod it for easy installation as posted elsewhere by cutting the cross member. Easier than having the gf return the one she probably already has and mail ordering the Mo-Tech.
post #13 of 36 Old 12-11-2006, 12:15 PM
PHOBMAN's Avatar
I made a stand for my California model that uses the center stand holes, and when your done changing tires or shocks you simply pull the pin and remove it. California models need to have the cannister removed!
PHOBMAN is offline
post #14 of 36 Old 12-11-2006, 03:00 PM
I had a H-D
west467's Avatar
Pictures?
What did you make it out of?
west467 is offline
post #15 of 36 Old 12-12-2006, 08:05 AM
PHOBMAN's Avatar
I have made a lot of sportbike stands, but this one is specifically designed to fit the 919. I made it from 1"x2" 14swg square tubing. This stand works the same way a centerstand works. I'll take a picture tonight and see if I can figure out how to post it!
PHOBMAN is offline
post #16 of 36 Old 12-12-2006, 10:14 AM
I have the centerstand on my bike... and it is what I use for general maintince.. for some things however I can see the need for a rearstnad and a frontstnd (like pictured) I have the rearstand simalar to the one in the picture except mine will also work with spools (its a pitbull) the bike spesific part of the frontstand is the pin that fits into the headstock of the bike. someone here I am sure would know which pin to get or you can look it up on bitbulls website http://www.pit-bull.com/catalog/index.php?cPath=23
(actualy I went and looked it up its the standard pin plus #1 adapter)
and personally I would get the forklift and converter version for 40 extra bones the combination of flexibility of use and garage space savings over winding up with 2 seperate stands would be hard to beat in my head
Mitch
'83 Suzuki GS750E
'02 Honda 919
Roseknight is offline
post #17 of 36 Old 12-12-2006, 12:14 PM
PHOBMAN's Avatar
The problem with rear swingarm stands is that you cannot change your shock or take your swingarm off!
PHOBMAN is offline
post #18 of 36 Old 12-12-2006, 12:17 PM
I have the SW-Motech centerstand on mine. No-mod, no exhuast removal. It takes about 15 minutes to install with the spring tool twistedthrottle sells.
mudarra is offline
post #19 of 36 Old 12-16-2006, 02:21 PM
PHOBMAN's Avatar
Here is the maintenance center stand I made for my bike, Just pull the pin and it detaches so you can ride without the exta weight and annoyance of a permanent centerstand!
PHOBMAN is offline
post #20 of 36 Old 12-16-2006, 02:57 PM
I made one similiar to that for my Hurricane. They work really nice. You can block up under the engine and tear the entire bike down, swingarm and front forks off, etc. Looks nice.
post #21 of 36 Old 12-16-2006, 04:54 PM
I had a H-D
west467's Avatar
Nice
Thanks for the pics...I wish I had access to a good welder.
west467 is offline
post #22 of 36 Old 12-16-2006, 10:01 PM
That is awesome, I want it, how much???
motorwerks919 is offline
post #23 of 36 Old 12-17-2006, 03:13 AM
Ken
Community Admin
Ken's Avatar
LoL - I was thinking the same thing!
Mass production anyone?
2009 Honda Goldwing
Ken is offline
post #24 of 36 Old 12-17-2006, 05:25 PM
I need to bring the camera to work sometime... I'm an auto mechanic, and I use my side-post hoist at work to lift bike from the swing arm. Looks ridiculous, is a two person operation, but it gets the job done.
Fighting Uruk-Hai is offline
post #25 of 36 Old 12-17-2006, 07:40 PM
PHOBMAN's Avatar
I would sell that stand for $60 plus UPS.
The only disadvantage it has is that you have to get on your hands and knees to fit it up before you deploy it!
PHOBMAN is offline
post #26 of 36 Old 12-18-2006, 01:37 PM
I had a H-D
west467's Avatar
PM'ed you..
west467 is offline
post #27 of 36 Old 12-18-2006, 01:58 PM
Can you make another?
post #28 of 36 Old 12-18-2006, 04:02 PM
PHOBMAN's Avatar
MOTORWERKS,SUGS,MOUNTAIN ROAD, WEST467, KEN,
I sent you pm's.
PHOBMAN is offline
post #29 of 36 Old 12-18-2006, 11:24 PM
Naked in Cheese Land
Anti-Shadows's Avatar
handy industustries makes a good stand and they are affordable
Anti-Shadows is offline
post #30 of 36 Old 01-12-2007, 03:54 PM
I had a H-D
west467's Avatar
Ok, thanks to "PHOBMAN" I have a removable centerstand, works great, easy
first time....Thanks to Peter!!!
west467 is offline
post #31 of 36 Old 01-12-2007, 04:26 PM
I had a H-D
west467's Avatar
With Center Stand
Here it is wtih the help of Craftsman stands, Motovation Sliders, and HD Dyna lift blocks..the front tire is off the ground.
west467 is offline
post #32 of 36 Old 01-13-2007, 05:47 AM
Phob, I disagree with you assessment of the stock stand being heavy and annoying. But after seeing your very ingenious design, I can certainly see your point. Well done.
West, wouldn't a tie down strap to the rafter been a lot easier than the "block and jack" set up?
post #33 of 36 Old 01-13-2007, 10:48 AM
I had a H-D
west467's Avatar
Yes it would, I have not gotten that far yet. One could also strap down the rear of the bike and pull the rear tire closer to the ground..
west467 is offline
post #34 of 36 Old 01-13-2007, 05:09 PM
Canadian Blue
Mark919's Avatar
You guys are just too funny.
The stand is awesome and should be in production.
Mark
Mark919 is offline
post #35 of 36 Old 01-13-2007, 07:36 PM
PHOBMAN's Avatar
West,
I'm happy you like it.
Peter.
PHOBMAN is offline
post #36 of 36 Old 01-13-2007, 07:44 PM
PHOBMAN's Avatar
Mark
The stand is in production, and you can buy it for $60 & $8 S+H
Peter
PHOBMAN is offline
