Will this motorcycle jack work for a 919? - Wrist Twisters
post #1 of 8 Old 10-29-2010, 04:53 PM Thread Starter
Hi everyone. This is a probably a question for my Canadian friends mostly but any help would be appreciated.
I have a motorcycle jack/lift purchased from Canadian tire that worked with my former bikes (cruiser, dual sport) but now I have a 2003 919 and am nervous to use it because the exhaust pipes running along the bottom seem to be the only place I can lift it up from.
So the question is- can I jack it up from there or are the pipes definitely NOT load bearing?
evilkleg is offline
post #2 of 8 Old 10-29-2010, 05:25 PM
The pipes are not load bearing.
Not only are the pipes themselves not load bearing, neither is the bracketry, see the metal forming that goes up above the collector to hang the header from the frame. That bracket alone is enough to nix it, let alone the pipes themselves. You might be able to make a wooden cradle to sit on top of the hoist. The right side would be an easy do, rests points under the clutch and under the aluminum side plates that tie in the engine/frame/swingarm and provide the attachment points for the footpeg assemblies. The left side is more complicated, have not looked at it closely. Race stands are a better way to go.
post #3 of 8 Old 10-29-2010, 06:06 PM Thread Starter
That's pretty much what I figured...
Thanks for the advice!
evilkleg is offline
post #4 of 8 Old 10-29-2010, 06:48 PM
the only time i used my pipes to lift the bike was to get my front tire off.... i had jack stands under the pegs or slightly forward, so that there was maybe all of 20 lbs on the actual pipes when i put the jack under the front.... but other than that i would never lift the bike solely via the pipes.
post #5 of 8 Old 10-30-2010, 10:57 PM
schrock86's Avatar
I have the same jack and have made different adapters to fit bikes where the exhaust was in the way. I just got my project 919 the other day and will be making an adapter soon. Ill post a pic once I get it made.
schrock86 is offline
post #6 of 8 Old 11-07-2010, 03:50 PM
I have lifted my bike with a similar jack under the header with no issues. Usually use my Phobman stand or a wheel stand though, but it can be done.
post #7 of 8 Old 11-07-2010, 04:18 PM
post #8 of 8 Old 11-07-2010, 05:22 PM
Total Awards: 17
x2. Put her on the rear wheel stand and lift away. Did it way too many times on my 919 with no issues. There isn't that much weight to do any damage if you think about it. If you have center stand, even better - less force will be required to lift her by the headers
zaq123 is offline
