Will f3 forks fit? - Wrist Twisters
post #1 of 10 Old 04-10-2009, 06:31 PM Thread Starter
Will f3 forks fit?
So does anybody know if cbr600 f3 forks will bolt straight up to a cb 900?
joelpatrol is offline
post #2 of 10 Old 04-10-2009, 07:33 PM
Heavy Metal
ratdog's Avatar
f4i bolt up, need a new fender
not sure about f3
ratdog is offline
post #3 of 10 Old 04-10-2009, 11:46 PM Thread Starter
ok how about 97 cbr900 forks?
post #4 of 10 Old 04-11-2009, 03:21 AM
if they did fit that would be a GIANT step backwards...
post #5 of 10 Old 04-11-2009, 11:40 AM
Heavy Metal
ratdog's Avatar
JoeP, what year is your CB900?
Is it an early model CB900F or a later model CB900F2-7?
What is it about the forks you don't like.
There are several options for improving existing forks or replacing them with a set of alternate forks if that's what you want.
A little more info and we might be able to guide you to some tried and tested alternatives.
ratdog is offline
post #6 of 10 Old 04-11-2009, 08:53 PM Thread Starter
Ok heres the deal. Its an 07 cb900 and i bought it salvage with bent forks. I am after a bolt in replacement and an upgrade. I am aware of the f4i transplant and would like to pursue this route but so far have been unable to find some decently priced f4i forks. There is of course some on ebay but i live in Australia and by the time you pay freight plus exchange rate its starting to get a bit pricey. I am however able to get my hands on some f3 or cbr900 forks very cheap here in oz - hence the questions. If it comes down to it though i will just pay the extra and get the f4i's but i figure if its virtually the same as an f3 fork then whats the point of paying more? Thanks for all your help guys but im still struggling to get a straight answer on the f3/f4 compatability. Ive searched the forums but it appears no one has done this swap so its a bit inconclusive. A search of cbr forums has also proved fruitless... Stay tuned i guess. Will post photos when the bikes all finished!
post #7 of 10 Old 04-13-2009, 08:42 AM
Heavy Metal
ratdog's Avatar
Don't know the specifics of the F3 vs F4i fork.
Would have to check spring rates, travel, fork leg diameter, fork leg length, et cetera, so I can't answer your question directly, would need to do some research. Also, I don't recall anyone else performing the F3 swap.
I totally understand about the cost issue.
The only good news is that it's Honda so you have a fair chance it'll work.
If I get a break here at work, I'll do a little leg work and post back.
ratdog is offline
post #8 of 10 Old 04-13-2009, 03:04 PM Thread Starter
Thanks Ratdog you da man.
post #9 of 10 Old 04-13-2009, 03:41 PM
The CBR 600 F3 fork stantions are 41mm, not 43, so without 1mm thick adapters they won't work on a 919 / 900 Hornet / cb900f. The first CBR forks that will fit are F4. That's as far as I can go -- I have no information on fender fitment or comparative widths.
Good luck.
post #10 of 10 Old 04-13-2009, 05:49 PM Thread Starter
Great info - thanks.
