Wierd Tire Wear on my 919 - Wrist Twisters
post #1 of 12 Old 04-17-2006, 02:21 PM
Dark8
Guest
Posts: n/a
I have Dunlop 208s on the bike and the front is either worn out or almost new depending on which side of the tread's groove you are looking at. The inner side of the groves treads looks to be at almost new depth but the outer side of the groove is down to the wear bars. The wear is the same on both sides of the tire and the tire has less then 3000 miles on it. No track days or any aggressive () riding.
Could this be from under inflation? I keep the front inflated to 36 psi cold, which is what the manual says is right for the bike.
post #2 of 12 Old 04-17-2006, 02:32 PM
Two Wheeled Warlord
Danke's Avatar
Rember 36 is the Psi for 2 up riding etc. I just can't create a mental picture your description, but it really comes close to something I've heard in the past. It's called cupping, and you wind up wearing the tire on one side from the camber of the road. You say it's both though.
Danke is offline
post #3 of 12 Old 04-17-2006, 02:42 PM
I'm not sure what you are describing, but it sounds like scalloping if it is symmetric on both sides of the front tire only. That can just happen street riding because you may not be countersteering. It generally happens to larger bikes and to softer tires. Try a different tread pattern. I have Metzeler's and it hasn't happened to me. Not sure if this helps.
blackbetty is offline
post #4 of 12 Old 04-17-2006, 02:55 PM
Dark8
Guest
Posts: n/a
Sorry my drawing skills aren't better but if you took a cross section of the tire the tread grove would look something like what I've attached.
post #5 of 12 Old 04-17-2006, 03:07 PM
Sounds to me like "cupping." I had the same problem with the 208's on another bike. Everything was correct including the tire pressure and a balanced front wheel. Changed over to Metzeler MEZ1's, I wore out 2 sets without any evidence of cupping.
post #6 of 12 Old 04-17-2006, 03:42 PM
Dark8
Guest
Posts: n/a
I have a set of Pilot Powers to put on this weekend. Just wanted to know if the cupping(?) could have been caused by wrong tire pressure, etc., so not to ruin my new set of tires. Thanks to all.
post #7 of 12 Old 04-17-2006, 04:21 PM
Honda Addict
razorbike's Avatar
That drawing is definitely cupping, Dark8. I had it bad with the original front Pilot Sport. It was so bad that it caused a wobble from 60mph on down. I ran that tire at 34 lbs most of the time but I think what got it was hard braking combined with a poor tread design. Now I have the Pilot Powers, 1500 miles on them and no worries.
The PP's are da bomb!
razorbike is offline
post #8 of 12 Old 04-18-2006, 12:25 AM
freind with a zx6r has the same issue... dunlop also... really bad too...
bridgestone front and rear... bt014 front 020 rear... really happy.
typhoonblue919 is offline
post #9 of 12 Old 04-18-2006, 12:11 PM
tomvan72
Guest
Posts: n/a
I have the same tires on my 919. I have noticed some wear similar to what you descibe and I just figured that it was because I was hauling ass and putting a beat down on the tires. I do find it funny that the front shows as much wear as it does. It is a newer tire than the rear. I dont tend to brake at full lean either. My riding buddies have the Pilot powers and they love them. Might be about that time.
post #10 of 12 Old 04-18-2006, 05:28 PM
Originally Posted by razorbike
...but I think what got it was hard braking combined with a poor tread design.
Bingo!
Dunlops + hard braking = cupping.
NewRedRider is offline
post #11 of 12 Old 04-20-2006, 09:48 AM
tomvan72
Guest
Posts: n/a
so I went home and had a closer look at my front tire. It seems to be wearing normal. i ave seen a tire that was cupping and mine is not. i dont brake too far into turns so I don't know if that affects it or not. I would make since if I did. I try to go slow to fast.
post #12 of 12 Old 04-20-2006, 01:27 PM
Dark8
Guest
Posts: n/a
I am hard on my brakes so that would explain the cupping.
