whats going on? - Wrist Twisters
post #1 of 7 Old 03-03-2009, 08:39 AM Thread Starter
whats going on?
Hi all I just have a question.
03 9ner, 20,000 on it. I start it up let it warm up then start riding. So here is the deal. I like using my throttle but the problem is that when I do it stops running between shifts. Kinda a safety concern of mine. If I don't notice it and let it into gear of course my back tire skids as the motor starts. Just thought I would ask the experts around here if they have any ideas.
Thanks
Mark
mdastrider is offline
post #2 of 7 Old 03-03-2009, 08:51 AM
91_4x4runner's Avatar
I'm no expert, but my guess would be a loss of spark.. Does it happen in neutral while revving as well? There's a plethora of things it could be (vacuum leak, fuel issues, spark etc)...
91_4x4runner is offline
post #3 of 7 Old 03-03-2009, 10:07 AM
once started, does it idle fine? Then it won't idle once you are going? While warming it up, do you have to keep giving it throttle input to keep it running?
post #4 of 7 Old 03-03-2009, 10:13 AM
if it is idling hard tell us what rpm it idles at.
post #5 of 7 Old 03-03-2009, 10:28 AM
Tire abuser
prtsimmons's Avatar
Do you mean it cuts out when you shift out of neutral? Does this happen under load only (i.e., when you are riding the bike)? If it cuts out whenever you shift into gear, it could be the sidestand cut-out switch. If it will idle but won't make any power, it could be an obstruction in the airbox or exhaust (dirty air filter, mouse nest in exhaust, etc.).
prtsimmons is offline
post #6 of 7 Old 03-06-2009, 02:08 PM Thread Starter
It happens under load. Full throttle with a slow shift. Meaning if I don't immediately go into the next gear. She idles just fine and my idle rpm is set at around 1100rpm.
So first gear give it hell slow shift cause I have reached speed limit bike kills.......... It just seems like it is starting to do this more often.
Thanks
Mark
post #7 of 7 Old 03-07-2009, 05:52 PM
Don't warm it up. Of course also don't slam the throttle to the stop with a stone cold motor. Excessive cold idling, especially with the enrichener on, can leave carbon deposits on the plugs which can take a while to burn off.
Thanks
Mark
Thanks
Mark
In order to diagnose this we will need everything you can think of regarding the fuel you use, weather conditions, engine temperature, what exactly you mean by "shifting slow" (it should take around 100 milliseconds -- non synchro transmissions do not take kindly to being shifted slowly), what your common shift RPM is, any and all modifications, and pretty much everything else that comes to mind. It does sound electrical, but which part is causing it is up in the air.
