What Type Of Fuel - Wrist Twisters
View Poll Results: What Octane Pump Fuel Do You Use
Regular - 87 74 54.41%
Plus - 89 14 10.29%
Premium - 91 48 35.29%
Voters: 136. You may not vote on this poll
post #1 of 46 Old 09-03-2008, 12:56 PM Thread Starter
What Type Of Fuel
Just wanted to see what octane of fuel everyone is running...I've been running Premium but keep hearing about how lower grade fuel will result in higher power in 919s.
post #2 of 46 Old 09-03-2008, 12:59 PM
87, I found some Racing fuel at 76, 91 octane $6.50 a gallon!
post #3 of 46 Old 09-03-2008, 01:05 PM
Most people seem to say that regular octane is fine for the 919, but I've always run premium. It performs great and gets 45-50mpg, so why mess with a good thing? I also only use Shell V-Power or BP Ultimate, there really is a difference in gasoline, something I learned when I worked for VW.
post #4 of 46 Old 09-03-2008, 01:15 PM
Al
I don't know how our gas compares to yours, as there are several slightly altered versions of any one bike as per the needs of the country's fuel and anti-pollution requirements,, but over here we have 91 octane and 96 (regular and premium). When we bought our 919's the shop said to use 91,, or to put it more accurately, they said 91 will do,, but I run 96. I've used 91 in too many cars and a few bikes before to find they ping and overheat easier so I generally use 96 on anything... I know the argument goes a little deeper than that but that's my rule...
CeeBee919 is offline
post #5 of 46 Old 09-03-2008, 01:24 PM
Tirone??
Gotsteam's Avatar
I usually run 87, and every other tank with 91. Why? Who knows.... My bike runs great on 87. I usually only run chevron fuel as well.
2006 Honda 919
States visited on my 919
Gotsteam is offline
post #6 of 46 Old 09-03-2008, 01:24 PM
87. On occasion I'll run hi-test just to "clean" the injectors.
Lemonhead is offline
post #7 of 46 Old 09-03-2008, 01:54 PM
CB900 Hornet
Sturmmann's Avatar
Ceebee919 - You have RON rating. Your 96 is equivalent to 92 in the states. So using 91, it is our 87.
Lower octane differences is within the rate of burn in nanoseconds. Higher octane burns slower that is why you can advance your timing, run high compressions, turbo, supercharge, NOS...anything that increases overall engine compression needs higher octane so there will be less chance or pre-ignition. High compression is increased heat. Given the heat scenario, lower octane would ignite right when it exits the injectors...no good for any kind of performance. Fuel ignite by plugs...excellent!
Our hornets have 10.8:1 compression ratio...it is near the high side. Using premium helps stabilize performance. Less chance at detonation/ping when going WOT. If you have a tuned vehicle, using higher octane, if your setup requires it, is all for the better. IF you have stock setup...87 will be fine.
I always use 91 because the vehicles I drive/ride are not stock. My civic itr has 11.1:1 c/r and needs 96 (100 RON) or better to be in the optimal range. Unfortunately I can only get 91. Sister uses 91 in her 1.8T GTi. Dads SLK230 uses 91...until he sold it. Only person in the family using 87 is mum who drives a Fit.
Sister rides a GS500F and uses 91...it comes jetted lean from factory. Aircooled...so it's a hot running engine...not something quicker burning fuel should be in.
Sturmmann is offline
post #8 of 46 Old 09-03-2008, 01:58 PM
it's a honda, not a bmw
deuceWI's Avatar
hmm, limited options here.
I picked 91, but in Wisconsin Premium is 93.
I've never had a problem running premium fuel, but I have gotten some bad 87 in vehicles before (citgo water gas?)
deuceWI is offline
post #9 of 46 Old 09-03-2008, 02:08 PM
bucky's Avatar
the lowest octane useable without pinging yields the most power and best economy. in ALL motor vehicles, not just 919's. there's nothing about a 919 that makes that fact more significant.
that should be your guide. and never fill up when the tanker's dumping.
bucky is offline
post #10 of 46 Old 09-03-2008, 02:17 PM
Plus One.
Professional
post #11 of 46 Old 09-03-2008, 02:22 PM
+1. And don't piss into the wind.
post #12 of 46 Old 09-03-2008, 02:24 PM
....or tug on SuperMans cape!
Professional
post #13 of 46 Old 09-03-2008, 02:31 PM
CB900 Hornet
Sturmmann's Avatar
Awesome couldn't say it any better. The fuel that doesn't ping is the one you want to use. Any higher would be useless...unless you start modifying/increasing the engine output/compression etc.
post #14 of 46 Old 09-03-2008, 02:37 PM
Al
I thought there was something in it like that... Many moons ago when we ran leaded gas, I used to know the specs as I had to test many solvents etc,, but since this unleaded stuff came in,, I dunno it any more... I had an idea there was a difference... I'll tell you what... when we had leaded gas, it was crap,, not the gas itself but our rules and regs about gasoline specs let too many impurities or levels of impurities into the product and it was absolute crap quality. I believe we have better quality nowadays though...
post #15 of 46 Old 09-03-2008, 03:11 PM
boogerface
mikochu's Avatar
I use 93...why? I don't know. Where's my mom?
Michael Reyes
mikochu is offline
post #16 of 46 Old 09-03-2008, 04:09 PM
INFIDEL
Rob919's Avatar
87 Octane 91% of the time.
Rob919 is offline
post #17 of 46 Old 09-03-2008, 04:16 PM
I have tried all the different gas stations, and found that shell runs the smoothest and clenaest. The shell I go to have 87, 89, and 93 and I always put in 93 octane. I know some say its wasting the gas, but I would rather run the 93. Whenever I put in the 87 it made the engine run poorly. Just my opinion. Everyone is going to do whatever they are most comfortable with.
post #18 of 46 Old 09-03-2008, 04:52 PM
Tirone is my middle name
mattf's Avatar
87, always. anything else is a complete waste of money. If the engine is pinging at all, then go up a grade, still pinging, then try premium. (that's what my teacher told me in auto mechanics school and I have never found any reason to disagree with it from personnal experience.)
mattf is offline
post #19 of 46 Old 09-03-2008, 05:27 PM
I killed Barton664
Basspiece919's Avatar
same with me, the shell station is right by my house so thats what i normally buy, and you can definatly tell the difference between 87 and 93
Basspiece919 is offline
post #20 of 46 Old 09-03-2008, 06:25 PM
I use 87 only . Try to use tier one fuels like shell, bp, chevron or mobil. Buy gas at cleaner, newer places because they probably have fresher gas due to higher sales and cleaner storage tanks. Sport-touring.net has a recent post from a bmw guy who filled with premium fuel at a small town and got a load of water and sediment likely frpm the fact that premium sells poorly in rural areas and small towns so the premium storage tank may have some pretty old gas in there.
Having a small, modern combustion chamber and rich fuelling makes bikes like our 919 very resistant to pre-ignition and knock. Consider that honda designs, manufactures and warranties these engines. Would they recommend a fuel that would increase warranty claims?
Higher octane fuel resists detonation(knock) mainly by being more resistant to igniting under high temps/pressures. A sometimes unwanted side effect of this is that it burns very slightly slower. Honda actually ran into this problem in devoloping a 4stroke 250cc six cylinder race engine in the 60's. In testing, the engine would not rev to the 21,000 required to make the power needed to compete. The solution was to lower the compression a little so the faster burning lower octane fuel could be used. It worked.
robert4 is offline
post #21 of 46 Old 09-03-2008, 08:10 PM
Lone Wolff's Avatar
I run what's cheapest. Most stations here it's the 10%ethanol 90 octane. Premium(91) is about .20-.25 higher per gallon. Seems like a waste for one more octane point.
2006 Honda 919
Lone Wolff is offline
post #22 of 46 Old 09-04-2008, 08:08 AM
I Love Parallel Twins
Naked/SS's Avatar
Regular 87 octane from Sunoco, Shell, or Hess but absolutely never from Citgo or Valero.
Most Citgo stations around here have gone out of business or changed their brand affliliation.
JDubya
Harleyville, South Carolina
USA
Naked/SS is offline
post #23 of 46 Old 09-04-2008, 08:24 AM
I use premium everytime (rages from 91-93).
If I have a choice I pick BP.
Consistently getting 40mpg
omaha_919 is offline
post #24 of 46 Old 09-04-2008, 10:14 AM
Didn't LDH do some Dyno runs with 87 fule that proved to make significantly more horsepower than 91 did in the same 919?
I know that my stock 919 runs stronger (seat of the pants Dyno) and gets better milage with 87 than it does with 91, but maybe it's because I'm just so damned Good looking.
Professional
post #25 of 46 Old 09-04-2008, 10:21 AM
I think that a lot of people don't realize your elevation is going to come into play as to which grade is going to perform best. Also depending on how you ride you will notice a difference. If you run it in the upper RPM's frequently "like me" you probably notice the Premium works best, if you’re just lugging around town or on the Highway you'd never notice a difference so 87 is going to be just fine.
Also, If anyone has ever worked at a gas station they can confirm this. When they go out to the pumps to take reading for the gallons pumped (or at least back in my day we did) you are only taking two reading!!! Regular and Premium!!! What about the Mid grade you ask? Well the premium meter is clicking away while the 89 is being pumped... If you have a Sams Club around you, you will notice that they only offer 87 and 93 octane. The 87 is basically the same price as everyone else in town, but the Premium 93 is the same price as the Mid grade at the other stations?
Just Some Food For Thought!
I run the 89 in my BMW and Land Rover that both call for Premium. Never had an ill effect or knocking with either.
Ripper is offline
post #26 of 46 Old 09-04-2008, 10:45 AM
Makes perfect sense (about more power), as it will burn faster and more completely than the premium. I'd bet that the graph also showed the 87 fell off in the upper RPM range and the Premium didn't really come on until the upper RPM's. There are trade off's to both. Depending on you're elevation, humidity, ambient temp and if you've had your bike tuned you could make gobs more power on 87. To many variables... But I know you already know all that Mr. Hasbeenracer!!!
My motto is: "Squeeze it Tight Before You Light!" or "Its always a better Bang when its tight" In other words Compression, compression, compression! Heck, my quad was pushing 15.1, a few more points and I could have run Diesel. I was in the process of converting the carb to run E85. Talk about bang for the buck!!! 105 octane rating at 1/4 of the price of Race Gas!!! But sold the quad before I ever got it done.
I'd love to get the 9'er up around 12.5 (depending on tuning maybe even 13.1) so you can still run pump gas but really benefit from the added compression.
Ripper is offline
post #27 of 46 Old 09-04-2008, 11:04 AM
Corner speed sets u free
streakin919's Avatar
i just got 47mpg out of my last tank o gas. a mix of low speed commuting and one medium speed jaunt through the hills one day (about 60 miles of it). Chevron 87 oct. Another thing to consider, if it hasn't been mentioned already, is fuel quality. Results will vary.
streakin919 is offline
post #28 of 46 Old 09-04-2008, 12:11 PM
bucky's Avatar
i've only ever really heard of one brand standing out as being of better quality: shell. other than a few anecdotals here and there.
bucky is offline
post #29 of 46 Old 09-04-2008, 02:52 PM
Prepare 4 surprise attack
Sgt_Mojo's Avatar
In my experience I also felt the premium had a slightly better throttle response and more of a purring sound in the high rpms and the regular more torque (but feel of course) on the take off.
Simon
Sgt_Mojo is offline
post #30 of 46 Old 09-04-2008, 03:39 PM
I LIKE THAT!
Fuel quality is VERY important and results vary widely here in SO.CAL.
I've had good luck with Shell and Chevron, but one brand I will never use again is ARCO. I will walk before I put that CRAP in any of my vehicles again. It's my understanding that Arco formulates their gas differently than any of the other majors.
Professional
post #31 of 46 Old 09-04-2008, 04:21 PM
BrokeRecord
I don't believe there's a single person on this Forum that can tell the differance in the brand of gas, oil, tires, or filters if they don't see the name when it's installed. We all find something about a product we like and to us it's the best. The only thing I look for is how much ethanol. If it's in the gas it's got to be posted on the pump.
brokerecord is offline
post #32 of 46 Old 09-04-2008, 04:36 PM Thread Starter
Since we're on the topic of gas and several are running ethanol fuel, have you seen any ill effects from it? The reason I'm asking is...we ran it in dad's ski boat earlier this summer down at Land Between the Lakes and it clogged the fuel filter. Actually, the alcohol (ethanol) in the fuel broke down the deposits/crud in the fuel system which then clogged the fuel filter. Also, are their good effects to running ethanol fuel such as cleaner injectors, etc...?
post #33 of 46 Old 09-04-2008, 04:50 PM
I disagree.
I can certainly tell a difference between tires, even if I can't see the name when they're put on. Performance in the rain, ability to handle quick input, feel at full lean, are very noticable. Could I tell you the brand by the ride? No. But I can notice a difference.
I notice the performance of oil and filters, not so much by the name when put on, but by the appearance of the oil when it comes out. It better be somewhat dirty when I change it if it's an oil with detergent in it. The job of that is to clean. The oil needs to gather it. Clean oil after 2,000 miles would scare me. The smoothness of the shifts is also an indication of the oil to lubricate. Can I tell the brand by this, no. But I can tell the performance.
Brand of gas, not so much unless the motor is pinging. That's obvious to someone who has experienced it before though.
I've spent so much time in the saddle of the 9 that minor changes stand out pretty quick.
post #34 of 46 Old 09-04-2008, 07:10 PM
Lone Wolff's Avatar
Not correct.
Sam's Clubs here do not offer premium. Regular Unleaded(87) and 'Super' Unleaded(89-90) only.
2006 Honda 919
post #35 of 46 Old 09-05-2008, 08:19 AM
wickedcobra's Avatar
87 only. If the book said 91, it would get 91. I have never had any problems with 87 so I won't give oil company's any money I don't have to.
wickedcobra is offline
post #36 of 46 Old 09-05-2008, 08:26 AM
Originally Posted by Lone Wolff View Post
Not correct.
Guess thats what I was trying to say? The premium and mid grade fuels are one and the same!
Ripper is offline
post #37 of 46 Old 09-05-2008, 08:46 AM
I spoze I should also add that mine's bone-stock. The only time I notice knocking or pinging is when I'm lugging the motor horribly. Any one who owns a niner knows how hard that is to do.
post #38 of 46 Old 09-05-2008, 01:10 PM
hawkeze's Avatar
I always used 89 octane, I thought it is what the manual indicated, but if most of you are getting good performance with 87 I'll try it for a while. I don't use gas with ethanol it in anything I own, it clogged the filter on my 63 Fairlane a few months ago.
hawkeze is offline
post #39 of 46 Old 09-05-2008, 01:28 PM
ajcombs's Avatar
Helping a Member in Need
funny I had that same feeling with that bike! do you notice it seems to smell less when running shell as well?
ajcombs is offline
post #40 of 46 Old 09-05-2008, 05:30 PM
Brain stolen again?
91 CAUSE MY MOTOR WOULD BLOW WITHOUT IT.
Mathew Quigley
