What? Lazy on a 919. - Wrist Twisters
post #1 of 22 Old 07-04-2008, 06:28 PM Thread Starter
MisterB's Avatar
I have found myself doing a lot of "speed shift" lately on my '02 919... any short/long term potential damage???
PS: I do ease on the throttle a wee bit just to take the load of the gears when I shift up.
...am I being lazy or it is just a great way to smoke it?
MisterB is offline
post #2 of 22 Old 07-04-2008, 06:49 PM
Sixty-9er
edgecrusher4444's Avatar
The lever on the left is there for a reason...
"Grip it and Rip it!"
edgecrusher4444 is offline
post #3 of 22 Old 07-04-2008, 06:56 PM
I only use the clutch to upshift when I'm stuck behind someone driving slow. I know someone else on this forum who almost never uses the clutch to upshift and he has over 50,000 miles on the bike with no ill effects.
post #4 of 22 Old 07-04-2008, 06:57 PM
propulsion's Avatar
If it is done right, it is very smooth. I don't see major damage occurring. The clutch is definitely required for certain situations, especially at low speeds.
We need someone to report on the long term effects of doing this.
propulsion is offline
post #5 of 22 Old 07-05-2008, 01:04 AM
As quoted from a certain member here, paging Rob, "So that's what that lever on the left is."
post #6 of 22 Old 07-05-2008, 07:17 AM
There is a difference betwixt speed shifting and clutchless shifting.
Speed shifting you hold the throttle wide open and use the clutch lever when you shift.
Clutchless shifting is when you momentarily get off the throttle and the instant there is no load on the gearbox, you go into the next gear.
When speed shifting there is an instant there is no load on a screaming engine. Then BAM the clutch has to deal with the load of a fully revved engine. So IMHO, speed shifting id abusive. I never do it.
Clutchless shifting, when done correctly and smoothly induces almost no stress on the engine, clutch or gearbox. I almost never use the clutch upshifting and only about half the time downshifting. Nearly all semi drivers seldom use the clutch.
post #7 of 22 Old 07-05-2008, 08:10 AM
Franklin McGillacutty
riquefied919's Avatar
AHHH the art of floating thru the gears as someone who drove a semi in chicago I'll tell you the more clutch foot stays on the floor the better your left knee feels. Having said that a gear box in a semi is unsyncronized and easier to float. Unless your real good or looking to knock off time on your drag et's your better off using the clutch.
riquefied919 is offline
post #8 of 22 Old 07-05-2008, 10:32 AM
+1
Long term effects? It depends on how you do it.
When I first started riding I usually used the clutch to shift, but felt there was a better way to do it. Once I started to riding on twisty roads such as GMR I stopped using the clutch for upshifts and have been doing it ever since. I must qualify that by saying I use the clutch to downshift most of the time to prevent excessive engine braking when setting up for a corner -- slipping the clutch helps keep the rear tire hooked up under hard braking.
In the 40 years and well over 500,000 miles of riding hundreds of different motorcycles I have not had a trans failure due to wear or damage from clutchless shifting, and I tend to hang on to bikes for a very long time -- my '88 Honda Hawk GT, which I still have, has right at 150,000 miles on it and the notoriously weak trans was doing fine until a crash in a diesel fuel slick jammed the shifter hard enough to break a shift fork.
A quick overview of the internals of a typical motorcycle trans drafted on my CAD program:
Gears engaged. As long as there is a load from accelerating, decelerating, or steady riding the gears are locked together.
Disengaged. When the load is interrupted either by rolling off/on the throttle or pulling in the clutch the engagement dog faces lose contact and the sliding gear is free to move. It takes very little time for this to happen.
Blocking happens about 60% of the time when engaging the next gear regardless of whether you use the clutch or not -- the shoulders of the dogs meet and have to slide scross each other to drop into engagement. This can be felt as a "step" in the travel of the shift lever.
This blocked condition is when most damage happens. If too much force is applied to the shift lever, the film of oil between the shoulders is pushed out, resulting in metal to metal contact. As the dogs slide across each other the contact area decreases and wear increases, reaching a maximum just before they clear enough to engage, rounding the corners. Once there is enough rounding the faces will become angled, eventually pushing them apart with sufficient force to overcome the tension of the detent, causing jumping out of gear usually under hard acceleration, but eventually all the time.
In order to prevent this, apply only enough pressure to the shift lever to move it (plus a little) and keep this pressure applied until the next gear is fully engaged -- the false engagement of the blocked condition can feel like full engagement, but if you let off the shift lever at that point the only force completing the shift will be from the detent roller, which is insufficient and will cause partial engagement or skipping/grinding.
Shifting without the clutch will not cause any more wear than with the clutch as long as you learn how to do it properly, and with experience can make shifts practically undetectable other than a change in exhaust sound.
post #9 of 22 Old 07-05-2008, 02:28 PM
Excellent tutorial as usual Rob!
post #10 of 22 Old 07-06-2008, 09:42 AM Thread Starter
MisterB's Avatar
That you all for the clarification.
MisterB is offline
post #11 of 22 Old 07-07-2008, 01:42 PM
Tonight we ride
Nemo's Avatar
Thanks Rob--amazing clarity as usual.
Nemo is offline
post #12 of 22 Old 07-07-2008, 04:21 PM
Bazooka Moe's Avatar
Check out the brain on Rob! Thanks man.
I've been getting worried about what that was occasionally when shifting.
My old X-6 Suzuki used to do it now and then. I don't remember it being as much as my 919.
Thanks again!
Bazooka Moe is offline
post #13 of 22 Old 07-07-2008, 04:47 PM
Dragon Slayer
oak1971's Avatar
I do clutch less shifting all the time. Been doing it for years on many bikes. But only up shifts and only when accelerating conservatively. I always back off the throttle a bit too.
oak1971 is offline
post #14 of 22 Old 07-07-2008, 06:55 PM
firedave's Avatar
Thanks Rob, tried this last night and found that I was shifting very smoothly after only a few tries.
firedave is offline
post #15 of 22 Old 07-07-2008, 07:37 PM
Thanks again!
By "that" I assume you mean partially engaging or grinding into the next gear. Or is it the step in the lever travel? It just takes a small adjustment of the shifting procedure and getting used to what it's telling you.
BTW, I had an X6 as well -- which I modified for 250 GP class (believe it or not), and it was posessed of a trans with 5 neutrals and an occasional gear. I cured this by undercutting all the dogs by about 2 degrees to tend to pull deeper into engagement, ramping and deepening the detents on the shift drum, and installing a much heavier detent spring. No problems after that. It did, however, go through a crankshaft every race. I got so good at removing the crank it only took about 30 minutes once the fairing was off. Unfortunately, its 47 HP was no match for the TZ 250's 51-54 HP, so I retired it.
post #16 of 22 Old 07-08-2008, 05:36 PM
Trackday Recognition Veteran
I guess it's time for an inspection for mine. Twice at Willow Springs last Sunday, I was upshifting to 5th going to turn 7, when I ended up with no gears.
That wasn't as bad as going to turn 1 at 120+, downshifting to 4th in the brake zone without applying any brakes, and ending up with nothing.
Visions of flying through the dirt only lasted a nano second. Any thoughts of braking were dismissed instantly. I downshifted again, set up for the left hander and gassed it hard. The fear disappeared with the flying vision. :001_smile:
Wonder how long it takes to tear down the lower crankcase?
Sokali is offline
post #17 of 22 Old 07-08-2008, 06:58 PM
daveb's Avatar
Smile
Damn Rob, Too bad you don't live here in the north east, and were into sleds. I'd love to see some of your mods to the clutches.
daveb is offline
post #18 of 22 Old 07-08-2008, 07:23 PM
Rob,
About time you got back; how was the ride?
GMR, when?
Sokali is offline
post #19 of 22 Old 07-08-2008, 07:34 PM
I think it's the step I've been mistaking as 'shift complete' at times. Not that it was grinding, but just didn't feel like the shift cycle had been complete. Today I wasn't so quick to backoff the lever when it seemed like it needed a moment, and I could feel a 2nd nudge of the lever, and I knew it was fully engaged.
I know I'm getting learning and getting used to the 919. Like making more of an effort to match RPM and MPH. That alone seemed to make the 'half-shift' disappear. I'll keep at it.
It's been a little difficult this week. I only ride six miles to work, and it's been a little rainy lately. I'm more sure of myself on one hand, and respecting the 919 on the other! There are so many nuts on the road I can't let my guard down for a sec. I think I'm about due for a relaxing ride. Oh, and a MSF course or track day to learn how to dance with this bike. (I digress).
Say, I guess you did quite a bit with the X-6! I only had mine for a year but it was great fun. Mine shifted fine unless I got sloppy. Then it'd just slip out of gear and remind me to behave.
The biggest troublemaker you'll probably ever have to deal with, watches you from the mirror every mornin'.
post #20 of 22 Old 07-08-2008, 10:22 PM
Church of the Holy Smoke
MotoCycho's Avatar
http://www.vf750fd.com/blurbs/shifting.html
I am pretty sure this was posted here by someone several years back.. either way.. more pics and groovy details.
- Rev. CYCHO -
MotoCycho is offline
post #21 of 22 Old 07-09-2008, 10:19 AM
bucky's Avatar
i believe those who are missing shifts periodically are not "sure" enough in their foot movements. sometimes i get sloppy and really only stroke the lever through part of its proper travel.
that lever on the left is for leaving a stop, by the way. sometimes i use it for downshifts as well.
bucky is offline
post #22 of 22 Old 07-09-2008, 02:30 PM
Practice, Practice...
