What is this part called and where can i get one? - Wrist Twisters
post #1 of 6 Old 04-27-2015, 09:47 PM Thread Starter
Makar919's Avatar
What is the silver expanding contraption called? where can i get some cheap?
Makar919 is offline
post #2 of 6 Old 04-27-2015, 10:59 PM
It's a 22mm (standard metric inside handlebar diameter, I believe) expanding collet...
You might have to contact the mirror manufacturer to get one specific for the mirror you are trying to mount.
The different sizes pictured above are probably for different sizes of bars (1" vs 7/8th's(22mm)).
post #3 of 6 Old 04-28-2015, 08:36 AM
SGKukov's Avatar
it is a called a gizmo, it goes in the whoozywhatzit, it is torqued down to correct specs using the thingamajig, if you neglect to follow proper installation you will suffer a catastrophic failure of the contraption
SGKukov is offline
post #4 of 6 Old 04-28-2015, 10:57 AM
Riding Naked All The Time
lococnc's Avatar
Barkbusters Bar End Mounting Kit 10mm Alloy Insert - RevZilla
Need to figure out what diameter you need inside the bar though...
2004 919 Uranium
lococnc is offline
post #5 of 6 Old 04-28-2015, 01:07 PM
Any cheap bar end mirror will use that very thing. You can get em at cycle gear, eBay, etc. Might have a few myself. Just an fyi they don't work very well. The rubber ones are much better.
post #6 of 6 Old 04-29-2015, 02:19 PM
We sell the version made by CRG. They work exceptionally well, sometimes too well
CRG Mirror Mount Kit - you will need one kit per mirror
