What does 77,000 miles look like? - Wrist Twisters
post #1 of 24 Old 04-24-2010, 11:21 AM Thread Starter
touring919's Avatar
Couldn't resists. The engine was just sitting there and I had 30 min to kill before coming in to get ready for a wedding. Not mine, the wife's co-worker.
Anyway. After 77,300 miles some may know I broke my frame. Engine ran fine. So I wondered what it looked like on the inside. Here it is. Cross hatching visible plane as day. Minimal vertical scoring of the cylinders. Combusion chambers pretty darn clean. Especially since the last time it ran I forgot I turned it on and let it sit idleing for an hour or so while I mowed grass.
Valve clerance was like this. (i never adjusted the valves. Ever.)
I: .007/.006 .008/.007 .007/.007 .007/.006
E: .008/.009 .010/.010 .011/.010 .010/.010
Spec is I= .006 +/- .001 and E = .010 +/- .001
Only two valves out of spec!!!!!!!!!!!!!!!!!!!!!!!!!!!
As you can see the cam bearing surfaces look great. Who knows what the clearance is (i don't have mics) but judging by the valve clearance i'd bet they are okay.
02 919 (RIP)
07 600RR
07 CRF450X
81 XS850
09 Versys
touring919 is offline
post #2 of 24 Old 04-24-2010, 11:24 AM Thread Starter
touring919's Avatar
Here are pics of the cylinders.
And one intake port pic.
02 919 (RIP)
07 600RR
07 CRF450X
81 XS850
09 Versys
post #3 of 24 Old 04-24-2010, 11:38 AM
+1 honda pwns. 2 questions.
1. how u break your frame.
2. what oil did you use?
post #4 of 24 Old 04-24-2010, 11:43 AM
Ride Offensively
FloridaMountaintop's Avatar
If it ain't broke.............
I would put it back together and get the frame welded or replaced and put another 77K on it!
I Can and will ride anything!
Bikes I own:
New addition 1978 CB750Four
2006 919
1994 home built springer
1984 KLR 600
1985 Honda 200M ATC
1985 Honda ATC 70
YEA BIGDAA I Gotta GUN!
FloridaMountaintop is offline
post #5 of 24 Old 04-24-2010, 01:15 PM
Hippie Tinkerer
mntnceguy's Avatar
Thanks for taking the time to post up those pics....Love it...engine looks great, running a little rich but in great shape...gotta Love a Honda!!
Build List in Spoiler
SOLD SOLD SOLD
When Sold:
599 Headlight
Koso Gauges DB-02r
GiPro gear indicator
Givi Crash bars
Seargent seat w/ gel insert
Dyna Beads for tire balancing
Piaa horns 400 & 500 hertz
Tech-Spec custom tank Pads
Napoleon bar end mirrors
SW-Motech center stand
Shorai Battery
Hydraulic rear brake switch
Powdercoated: 22+ parts
etc, etc,
mntnceguy is offline
post #6 of 24 Old 04-24-2010, 03:20 PM
Philanthropist
Dave W.'s Avatar
Awesome.
I would like to know what (if any) break in process you followed.
Thanks
Dave W. is offline
post #7 of 24 Old 04-24-2010, 03:43 PM
Gets censored
Nice! thats exactly why i ride hondas, period. +1 on the oil, what kind?
brian is offline
post #8 of 24 Old 04-24-2010, 03:57 PM
How exactly did you break your frame? That had to take some work.
post #9 of 24 Old 04-25-2010, 07:00 AM Thread Starter
touring919's Avatar
https://wristtwisters.com/naked-bikes...retirment.html
explains all.
Yea, it could have been fixed if I had a TIG but I couldn't ressist the excuse to get a new bike. And I have to admit I love my 1000 now. Insane bike. Needs a turbo though
It was my 1st bike. So break in was probably pretty tame considering I was sscared to death on the bike. Rode it easy. Shifted at 3k and gradually raised the shift points as I got more comfortable and confident with the occational WOT pull in a taller gear that wouldn't cause be to poop my pants.
Since then it was run HARD but also had lots of highway miles. Keep in mind my ridde to work is between 3 and 7 miles and the bike would hit the rev limiter at least once each direction typically parked before temps would even get up to normal. Highway stuff of coarse is easy on an engine.
This wass actually the dirtiest I have ever seen the plugs. For sure letting it sit at idle for an hour blackened things up. Whish I could have pulled it apart right after running it in its normal daily use.
02 919 (RIP)
07 600RR
07 CRF450X
81 XS850
09 Versys
post #10 of 24 Old 04-25-2010, 07:10 AM
My '02 at 35k, good to know there's still a lotta life left in the old girl...maybe sinking a few more bucks in her ain't such a bad investment at this point after all.
honda ng gingsa is offline
post #11 of 24 Old 04-25-2010, 11:00 AM
*cough* what oil *cough*
lets end this debate once and for all!
post #12 of 24 Old 04-25-2010, 12:03 PM Thread Starter
touring919's Avatar
Honda oil. 10-40
Nothing special.
02 919 (RIP)
07 600RR
07 CRF450X
81 XS850
09 Versys
post #13 of 24 Old 04-25-2010, 12:51 PM
Originally Posted by touring919 View Post
Honda oil. 10-40
Nothing special.
ur spost to say rotella t 15w40 lol.
I figured it was some standard type motorcycle oil... it really isnt the oil that matters its how often you change it. plain n simple.
post #14 of 24 Old 04-25-2010, 05:43 PM Thread Starter
touring919's Avatar
Uhmmmm.
Maybe. I changed my oil every 4 to 6k miles wether it needed it or not. I think it has more to do with the fact that less than 100k is nothing for a modern engine. Bike or not.
02 919 (RIP)
07 600RR
07 CRF450X
81 XS850
09 Versys
post #15 of 24 Old 04-25-2010, 06:40 PM
Uhmmmm.
you were MEAN to that bike.... shame on you.
post #16 of 24 Old 04-25-2010, 06:46 PM
If one thinks of it in terms of being like a car engine, then what touring919 has proven is a reasonable expectation.
Modern oils in modern liquid cooled engines on modern gasolines.
No surprise.
Uhmmmm.
post #17 of 24 Old 04-25-2010, 07:33 PM
Fat guy on a little bike!
Byrdman's Avatar
The 919 frame is pretty sad and the failures you've experienced are exactly what I would have expected. The engine does look great though and maybe, just maybe a little fabrication and welding are in order. At least then you could sell the old girl to a young (motivated) rider?
Jeff
Byrdman is offline
post #18 of 24 Old 04-25-2010, 07:52 PM
i vote put the motor back together, pop in a long travel rhino build. I think that would be pretty fun, 107hp and 71 ftlbs in a side by side.
post #19 of 24 Old 04-26-2010, 01:38 PM Thread Starter
touring919's Avatar
It would be better in one of those little mini sand rails.
I have too many oother projects. So the plan is, sell the head to someone on here and then use the engine to add to my metric magic bolt box. Unless soeone is hard up for a crank/rods/cams and whatnot all that will either be trashed or used as man cave decorations.
02 919 (RIP)
07 600RR
07 CRF450X
81 XS850
09 Versys
post #20 of 24 Old 04-26-2010, 03:07 PM
ok ok CB900GC? GC= golf cart?? hahaha.. I like the idea of man cave decorations... clean it up n make a table with a clear top!
post #21 of 24 Old 04-26-2010, 08:13 PM
Pop it back together. It will make a dam fine lawnmower engine.
post #22 of 24 Old 04-27-2010, 12:24 AM
djmell762's Avatar
that should drive up the resale value of the 9er
04 919, 97 DR650
djmell762 is offline
post #23 of 24 Old 04-27-2010, 05:29 PM
bucky's Avatar
huh. you think there's posts like that very often on the Harley forums .... ? i mean, sure, seeing as they've built 29 billion harleys, just by accident one or two of them must keep running a little while, but...?
bucky is offline
post #24 of 24 Old 04-27-2010, 06:07 PM
haha ya serious
