What bars and brake fluid reservoirs are you running? - Wrist Twisters
post #1 of 11 Old 04-27-2015, 01:45 PM Thread Starter
Makar919's Avatar
Im not very fond of the stock bars and brake fluid reservoir (9er). What set up are you guys running on your bikes? Pics welcome!
Makar919 is offline
post #2 of 11 Old 04-27-2015, 02:04 PM
bartsitarski's Avatar
Originally Posted by Makar919 View Post
I not very fond of the stock bars and brake fluid reservoir (9er). What set up are you guys running on your bikes? Pics welcome!
I am running Renthal ultra low bars. As for the brake fluid, just the stock master cylinder. Eventually, I want to get a Nissin M/C with detached fluid reservoir and braided stainless brake lines, but, they are not on my priority list.
Aluminum 7/8" Universal Nissin Hydraulic Front Brake 5/8" Master Cylinder
7/8" Gold Aluminum Ultra-Low Renthal Superbike Handlebars | Gold Ultra-Low Renthal Superbike Bars
bartsitarski is offline
post #3 of 11 Old 04-27-2015, 02:18 PM
Renthal UL's here too, RC51 (SP2) master cylinder and reservoir to match the RC51 calipers I'm running
post #4 of 11 Old 04-27-2015, 03:50 PM
CB1000R bars and CBR954 M/C & calipers. I probably don't count though since I don't have 919 triples.
post #5 of 11 Old 04-27-2015, 07:26 PM
urdrvideo's Avatar
I'm using renthal ultra lows with CBR 929 master cylinder and a small Brembo reservoir
urdrvideo is offline
post #6 of 11 Old 04-28-2015, 10:41 AM
TharBars adjusted as narrow as possible: 22 1/2 inches to the ends of the grips. Yeah, I don't expect many to go this extreme, but the bars can be considerably wider. While I have no assembled bar sets at the moment there are plenty of components still available.
Frankly, I have never liked the Ultra Lows as they follow the typical dirt bike practice of rise instead of drop, requiring rotating back to get the controls in a comfortable position (drop instead of rise), and at least for me are way too wide. Again, personal preference.
As to the master cylinder, it's a 17.5 mm radial Nissin unit stock on all years of the CBR 1000 I got from Ebay for a paltry $48 including shipping. The calipers are stock, and the combination decreases the effort at the lever slightly, which is the reason why I did this. The reservoir is (if I remember correctly) a rear brake reservoir for a GSXR 1000 I had laying around that took some modifying to decrease the diameter of the hose fitting, and mounted using a piece of 1/8" stainless steel welding rod. It's plenty strong for this application and places the reservoir as low as possible to cure the typical barnaclesque look of the normal mounts for a sport bike application which is hidden by a fairing. Contrary to popular opinion the reservoir does not have to be a gravity feed: as long as there is no air in the feed line it works just fine.
post #7 of 11 Old 04-28-2015, 01:04 PM
Batman
velodesign's Avatar
For whatever reason, your bike looks like its donating plasma...just sayin.
velodesign is offline
post #8 of 11 Old 04-28-2015, 02:54 PM
BockHawk's Avatar
I'm running Renthal mediums and an R6 Brembo m/c w/ the R6 reservoir. Rob's pic reminded me that I badly need to change my well aged brake fluid.
2002 919 40,000 miles
BockHawk is offline
post #9 of 11 Old 04-28-2015, 06:16 PM
Renthal ultra low's and the OEM reservoir. Although I did cut off the mirror mount, and it looks muuuch better now.
jnich77 is offline
post #10 of 11 Old 04-29-2015, 08:22 AM
Funny. The vinyl tubing in these old shots is there to observe air being ejected from the master cylinder during bleeding (the reservoir is difficult to see through) and by introducing a small air bubble in the line flow can also be observed. Obviously it has been replaced by more suitable tubing and clamps.
post #11 of 11 Old 04-30-2015, 04:56 PM
Batman
velodesign's Avatar
I dont mess with bleeding and plasma...that they are being used in this thread in different contexts should throw the google bots for a fun loop. Future plasma donors, please not to make sure its dot4 coming outta ya! Chuckle chuckle...
