Weird noises from the 9er - Wrist Twisters
post #1 of 7 Old 09-10-2007, 11:15 AM Thread Starter
Crotchety Rocket
cmelnick's Avatar
Donation Extraordinary Ride
Ok, the 2nd "weird noise" thread for the day. Mine just recently started making weird noises, mostly when the bike isn't fully warmed up, at low RPM (3000 or so), only when under load. (Yea, yea, this sounds similar to that other thread). Mine isn't a tapping noise, however, more of a rattling, grinding, choking type noise. Again, only under load, not when I rev the engine, and it disappears around 4k RPM or so. Sounds like it's from the engine, not transmission. Should I be concerned? It's just about right at 8k miles.
- Stephen Hawking
cmelnick is offline
post #2 of 7 Old 09-10-2007, 11:23 AM
Toll Runner
str8ghtjacket's Avatar
Make sure your chain is adjusted right and well maintained, I usally clean and lube about every 3-4 tanks of gas. Might not be the problem but wont hurt to do anyways, str8
str8ghtjacket is offline
post #3 of 7 Old 09-10-2007, 11:33 AM
Curmudgeon
semi_gray's Avatar
When I first started to ride my 919, I noticed a noise like the one you describe. Over time, I don't know if it's diminished, or I'm getting used to it, but it doesn't bother me anymore.
I suspect what we're hearing is valve chain slap and the tensioner doing it's thing.
Now, I'm anal about these kinds of things and if i've learned to live with it, so can you.
semi_gray is offline
post #4 of 7 Old 09-10-2007, 11:37 AM
Church of the Holy Smoke
MotoCycho's Avatar
Sounds like the signature 919 2500-4000 RPM headlight ring/bucket buzz.
- Rev. CYCHO -
MotoCycho is offline
post #5 of 7 Old 09-10-2007, 12:12 PM Thread Starter
Crotchety Rocket
cmelnick's Avatar
I'd buy that, but is it weird that it just recently started happening?
So a tightening or something may be in order? I'm thinking this isn't the issue, just because the sound really appears to be coming from the engine, not in front of the bike...who knows tho...
- Stephen Hawking
cmelnick is offline
post #6 of 7 Old 09-10-2007, 12:41 PM
A few years ago I rode a CBR, and the CBR motors (just about all years it seemed, but appeared to be more common on the F4i) were notorious for the cam chain tensioner lifter (CCTL) having issues after a few thousand miles and having to be replaced to eliminate the noise. It would make a horrible rattling sound between 4000-6000 RPM. I haven't really heard anything about that problem on the 919 motor, but I suppose it could be possible and maybe something to look into.
Here's an example: http://cbrworld.net/forums/thread/205481.aspx
psyccologicc is offline
post #7 of 7 Old 09-11-2007, 01:39 PM
I have just started noticing what I am guessing is the same thing. The bike is a couple weeks old with less the 400mi. When it is still cold there is a rattly type noise from 2500 to a little over 3000rpm. After it is good and warm I can't really hear it anymore. Same deal with needing to be under load to hear it. I guess I will check the headlight but like cmelnick it sounds more from the engine.
2015 Ducati Monster 1200S
FlyCatcher is offline
