Variable Air Intake Control Vacuum Tube - Wrist Twisters
post #1 of 10 Old 09-05-2008, 09:01 PM Thread Starter
Hello everyone.
Just bought a 919 from a fellow member on board.
It's an 04 with just over 10k on the clock. The bike has been lurching and shifting in an unusual manner and for some reason or another I decided that the intake mechanism is the culprit.
I removed the side cover and then removed the the air cleaner cover. To my surprise there was no vacuum tube connected to the back of the air cleaner. There was only a circular hole on the back side of the cover with nothing attached.
Furthermore, wedged up at the base of the tank was the variable air intake control vacuum tube. It was plugged with a screw.
Having never owned a 9er I'm not exactly sure how it's supposed to look. Furthmore, I have no idea what might happen if I remove the screw and fail to reconnect it to the air cleaner mechanism.
Thoughts?
mylexicon is offline
post #2 of 10 Old 09-05-2008, 09:12 PM
Thats called the "flapper mod" I think you'd be hard pressed to find even a mildly modded 9er that still has the flapper valve connected. I haven't noticed any difference on my '04 with the valve connected or disconnected, I've left mine disconnected just because I can.
post #3 of 10 Old 09-05-2008, 09:49 PM Thread Starter
Hmmmm.....thanks for the info.
What is the point of the flapper mod? Should I leave the screw in the vacuum tube?
post #4 of 10 Old 09-05-2008, 09:55 PM
287
287's Avatar
With the vacuum tube in place the flapper door is closed below about 5k RPM. The idea behind the flapper mod is to make the intake less restrictive by keeping the door open at all times.
287 is offline
post #5 of 10 Old 09-05-2008, 10:13 PM
yes definately keep that vacuum line plugged.
barmatt80 is offline
post #6 of 10 Old 09-05-2008, 10:13 PM Thread Starter
So I guess it's safe to ride on a long trip tomorrow?
Seriously, thanks.
post #7 of 10 Old 09-05-2008, 11:29 PM
919>food>beer
Jeef's Avatar
yeah its a honda... just make sure you check out the FAQ thread on this board, there area few issues with loose bolts that need loctite, if the previous owner was from here it probably is taken care of but it would be prudent to double chcek, especially the shifter bolt (lost mine before I check this site). there are a few other common problems like the starter wire breaking in the switch housing but no major engine or tranny problems.
Jeef is offline
post #8 of 10 Old 09-07-2008, 10:05 AM
+1 I lost the shifter bolt on mine as well. 2000 miles from home and the rider behind me saw my linkage hanging. Walking back a quater mile I was lucky enough to find the bolt.
post #9 of 10 Old 09-07-2008, 05:17 PM
Church of the Holy Smoke
MotoCycho's Avatar
Mine was cross threaded on and the bolt broke when I tried to remove it. It would have never come off in a 1000 years. I had to use a dremel to cut the clamp bracket off the shifter shaft and order a new one. I forget why I had to take it off at the time but it was necessary for whatever I was doing. Anyway.. Just thought I'd share my entirely opposite experience.
- Rev. CYCHO -
MotoCycho is offline
post #10 of 10 Old 09-08-2008, 04:35 AM
Franklin McGillacutty
riquefied919's Avatar
I preformed an radical flaperectemy on 9er removed it all door vacuum valve and pluged the line.
riquefied919 is offline
