Valve Cover Gasket - Wrist Twisters
post #1 of 17 Old 03-06-2009, 10:18 AM Thread Starter
Valve Cover Gasket
Okay...this is likely a dumb question but I'm going to ask it anyway.
I rode the 919 yesterday and today and have been loving it. However, when I parked it at lunch today, I noticed a little shimmer coming from the motor. The little half-circle rubber pieces on the left side of the bike have traces of oil just around the outer edges. So...what's up with that. The right side has just the slightest hint of oil, but nothing like the left side.
Is this a common thing to see after the bike sat on the side stand all winter? Is it normal for just a small amount of seepage? I've got somewhere betweek 18,000 and 19,000 miles on the bike and have not done the valve check yet, but plan on it after I get block-off plates from Semi_Gray in a couple weeks.
Any input would be greatly appreciated.
post #2 of 17 Old 03-06-2009, 10:28 AM
I'm going riding.
scrat's Avatar
it's a simple rubber seal there, check if your valve cover bolts have loosened for some reason. the seal could also be drying out some, it is a little unusual for something as new as a niner to dry out a rubber seal like that, but it could happen. when you check your valves inspect it very closely. the new gasket for the cam cover runs about 42 bucks.
scrat is offline
post #3 of 17 Old 03-06-2009, 10:29 AM
Tire abuser
prtsimmons's Avatar
My old 1985 CB700SC Nighthawk used to leak a little oil from the left side of the cam cover seal. It never caused any trouble. I would only worry if: (a) oil consumption is high; (b) there is whitish goo around the inside of the oil filler cap (evidence of water in oil); or (c) there is oil in your coolant.
That's just my 2 cents... I haven't noticed it happening on my 919.
prtsimmons is offline
post #4 of 17 Old 03-06-2009, 10:36 AM Thread Starter
Thanks for the quick replies. It is not consuming oil at a high rate by any means, the coolant looks nice and clean (although I'll probably change it just because), and there is no evidence of water in the oil. It also isn't smoking or anything else.
I'll check the bolts sometime this weekend.
Thanks. I wish I could change the title so I don't look like such a retard.
post #5 of 17 Old 03-06-2009, 10:39 AM
I'm going riding.
scrat's Avatar
I think the p/c term is now window licker, isn't it? either way, we won't hold it against you. it's a gasket on the head. same difference!
scrat is offline
post #6 of 17 Old 03-06-2009, 10:43 AM
3dcycle's Avatar
if it was i, i would find the leak and fix it, just because it is not causing a problem does not mean it it is right, looks gros fix it...
3dcycle is offline
post #7 of 17 Old 03-06-2009, 10:50 AM Thread Starter
Um...yeah...I'm mentally challenged...not a retard.
*Notice: the term Retard was not used to offend anyone.
post #8 of 17 Old 03-06-2009, 11:32 AM
It's ok Chris.... Go play with your crayons... And don't write on the wall.... And remember everytime you touch yourself god kills a kitten
post #9 of 17 Old 03-06-2009, 11:50 AM
.....yeah and get out your plastic phone and call the Easter Bunny. Tell him to bring you one of those gizmos that'll give your bike 122hp.
post #10 of 17 Old 03-06-2009, 11:59 AM
timbo813 is offline
post #11 of 17 Old 03-06-2009, 12:04 PM
bucky's Avatar
PICTURES !!
bucky is offline
post #12 of 17 Old 03-06-2009, 12:41 PM Thread Starter
Here are some from my phone. You can kinda see a little, but the pictures generally suck!!!
post #13 of 17 Old 03-06-2009, 12:58 PM
Not your head gasket..Just the valve cover gasket.Gotta come off when you get the valve clearances done anyway.Dont worry
flange is offline
post #14 of 17 Old 03-06-2009, 01:57 PM
3dcycle's Avatar
does not look like it is sitting in there very good, little twisted..... oh wait that might be me.
3dcycle is offline
post #15 of 17 Old 03-06-2009, 05:25 PM
Trackday Recognition Veteran
FWIW I got 49.6k on mine and have removed the cover 3 times for valve checks and adjustment. I'm still using the original seal. Just put some black silicone around the half-moon area when you check the valves.
I think the torque for the cover bolt is 7 pounds.
Sokali is offline
post #16 of 17 Old 03-07-2009, 11:35 AM
BrokeRecord
If that's all it is to the leak, I'd take an old rag and wipe it off once a week.
brokerecord is offline
post #17 of 17 Old 03-07-2009, 11:49 AM
3dcycle's Avatar
yea you could do that, or stay on top of things and fix it now. depends how much you like oil drips coming fom your bike.
3dcycle is offline
