Valve adjustment questions - Wrist Twisters
post #1 of 25 Old 09-06-2007, 05:55 AM Thread Starter
Unbannable
Super Sneaky Steve's Avatar
After taking a peak of the manual online part of the procedure seems fuzzy.
My first concern is with the cam timing. I know it's very important to get the cam sprocket in the right position but I'm unsure how to line it up exactly. I saw the marks on the sprockets but I didn't see any marks on the motor itself to line them up with. (I haven't looked at my real motor yet) Are there any marks like that? What happens if I'm off by one or two teeth?
Secondly, how do I get the cam tension back to spec? I read the part about the lil key thing you have to make, but once it's back on the motor how do you adjust it to spec?
Thanks in advance.
Super Sneaky Steve is offline
post #2 of 25 Old 09-06-2007, 08:17 AM
Curmudgeon
semi_gray's Avatar
The timing marks on the cam gears line up with the top of the head where the valve cover sits. The gears are coarse enough that if you're off one tooth, it'll be obvious you're off.
Take some time rolling over the engine before taking the cam out (if you need to take the cam out) in order to familiarize yourself with the marks.
Also, pay attention to the marks on the crankshaft that are revealed after removing the circular cover at the crank end on the cam side of the engine.
Cam chain tension is maintained by the spring tensioner you manipulate with the "key". Once things are back in place, un-wind the "key" and spring pressure takes care of the rest.
semi_gray is offline
post #3 of 25 Old 09-06-2007, 02:24 PM
BrokeRecord
Valve
Any time I disturb an OHC, I'll turn it over by hand about 2-3 times to make sure the marks are still right before I fire it up.
brokerecord is offline
post #4 of 25 Old 09-08-2007, 02:04 PM Thread Starter
Unbannable
Thanks for the tips guys.
Does anyone know of a good torque wrench? I've tried several different stores and the small ones always have 10ft/lbs on the short end. Some bolts call for as little as 7.
post #5 of 25 Old 09-08-2007, 03:10 PM
That's nacho cheese!
Craftsman...........
"Hey Pippin! Charlie Crawford ain't with ya anymore!"
Billy the Kid
post #6 of 25 Old 09-08-2007, 03:29 PM Thread Starter
Unbannable
Sears was the first place I went. I just wanted a cheap one, but I guess I"ll have to spend at least $200 on an electronic one to get the range.
I also failed in making a little cam tention key out of an Altoids box. Thank God I didn't cut my finger off! It's simply too flimsy.
Can anyone make one for me? I can post the dimentions.
post #7 of 25 Old 09-08-2007, 04:20 PM
Alaska bound
fehren2800's Avatar
Donation Donation Extraordinary Ride
Don't spend the money on an electronic one. Get a regular foot/pounds one and also an inch/pounds wrench. inch pounds wrench
The inch pounds version is good for 25 to 250 inch/pounds which is about 2 to 20 foot/pounds. Just multiply the foot/pound value by 12 to get inch pounds, so 7 foot/pounds would be 84 inch/pounds.
As for the key; I tried to make one out of various materials as well, and all were too flimsy. I used a piece of heavy metal banding. Go to Home Depot or Lowes and see if they have any laying around where they keep the wood bundles.
After many years and many dreams I have realized my goal of riding in all 50 states!
Now the rest of the world!
Every now and then go away and have a little relaxation. To remain constantly at work will diminish your judgment. --Leonardo Da Vinci
fehren2800 is offline
post #8 of 25 Old 09-08-2007, 06:43 PM
I am curious how many miles you have on the bike?
motorwerks919 is offline
post #9 of 25 Old 09-08-2007, 11:31 PM Thread Starter
Unbannable
I only have 6,500 miles, but I skipped the first check at 500 miles. I know I don't have to do it, but this Honda is so reliable I'm just hunting for things to do on it.
Thanks much for the wrench. They didn't have it at the store so I'll order it by the part number.
post #10 of 25 Old 09-09-2007, 05:40 AM
Ken
Community Admin
Ken's Avatar
PM coming on the key - I have one and no longer have any need for it.
2009 Honda Goldwing
Ken is offline
post #11 of 25 Old 09-09-2007, 01:34 PM
touring919's Avatar
I bet your getting worried about nothing. Check the valves. I doubt they are out of adjustment. Of coarse, being prepared to have to take cams out is not a bad thing.
touring919 is offline
post #12 of 25 Old 09-09-2007, 06:35 PM
I had mine checked by a shop at 15k (or 17k or whatever the manual specified) and the technician said the top end looked brand new. Everything was in spec and no adjustment was necessary.
ajohn505 is offline
post #13 of 25 Old 09-09-2007, 10:56 PM
Go'n So slow I'm stopped
xrmikey's Avatar
Valve clearance Inspection is to be at 16k per the manual.
He's got time.
xrmikey is offline
post #14 of 25 Old 09-10-2007, 10:16 AM Thread Starter
Unbannable
All the reviews I read for the sears wrench said it was crap.
Has anyone used this wrench?
http://www.harborfreight.com/cpi/cta...temnumber=2696
From the price it doesn't seem to be high quality, but the fact that it cost half as much would be better if it took a crap. The Craftsman is only warrentied for a year.
post #15 of 25 Old 09-10-2007, 11:06 AM
Crotchety Rocket
cmelnick's Avatar
I have the harbor freight wrench. It works fine, although I don't have anything to compare it against. What you DON'T want to do is use it for a torque value at the bottom or top of the range because they're inaccurate for the most part unless you're somewhere in the middle. I've snapped a bolt off because I was using the wrench at the bottom of its range.
- Stephen Hawking
cmelnick is offline
post #16 of 25 Old 09-10-2007, 03:45 PM Thread Starter
Unbannable
I caved and got this.
http://buy1.snapon.com/catalog/item....re&dir=catalog
And this to measure the lobes and shims.
So last question (maybe) Should I reuse the old valve cover gasket? and should I use some kind of sealant with it?
post #17 of 25 Old 09-10-2007, 05:21 PM
Corner speed sets u free
streakin919's Avatar
Electric Tourque wrenches
I've heard that the electric wrenches have problems... no more details than that, but at the price they want for them i wouldn't even consider one. I have the ft\lbs and inch\lbs craftsman, lifetime guarantee is hard to beat.
streakin919 is offline
post #18 of 25 Old 09-10-2007, 05:27 PM
If it were me i would replace the gasket with a new and would only use selant if it's required (in the manual). Nothing worse than going through all that work and finding the old gasket leaks once it's all back together.
post #19 of 25 Old 09-10-2007, 06:16 PM
xrmikey's Avatar
Why are you getting 1/4" drive instead of 3/8" drive?
You will have more range from the 3/8" as far as sockets go.
If you need to use 1/4" drive socket you can reduce it.
Just courious...
xrmikey is offline
post #20 of 25 Old 09-11-2007, 05:13 AM Thread Starter
Unbannable
I guess I screwed up on ordering. I"ll call them later and see if I can exchange it.
The Craftsman lifetime guarantee doesn't include all tools. The torque wrenches are only for a year.
post #21 of 25 Old 09-11-2007, 08:43 AM
wisco919's Avatar
Electric torque wrenches require frequent calibrating. A hard process to do yourself. Usually requires sending to a metrologist which can be pricey.
Just courious...
Adding adapters and extension can reduce the accuracy of a torque wrench by up to 15%. It is best to get the drive required for the socket you will use.
wisco919 is offline
post #22 of 25 Old 09-11-2007, 09:38 AM Thread Starter
Unbannable
Damn, I just called Snap-On and switched my order to a 3/8ths drive. Oh well, not going to change it again.
What kind of sealant do you guys use on your valve cover gasket? I hear Honda Seal is good.
I bought some moly grease for the cams, but all they had was stuff for axle joints. I assume it's all the same.
post #23 of 25 Old 09-11-2007, 11:53 AM
xrmikey's Avatar
Thats true for what ever drive you use.
The instructions should explain that.
The larger the drive the more accurate you will be. less twist on the extensions.
xrmikey is offline
post #24 of 25 Old 09-11-2007, 06:42 PM
xrmikey's Avatar
Don't sweat it Steve, you got the right thing.
xrmikey is offline
post #25 of 25 Old 09-11-2007, 09:45 PM
Toll Runner
str8ghtjacket's Avatar
6500 miles , I think your ok , Ive got 14K still in spec. str8
str8ghtjacket is offline
