Urgent help needed - tip to put 919 headers back on - Wrist Twisters
post #1 of 13 Old 01-21-2015, 09:23 PM Thread Starter
ewmin3m's Avatar
Hey guys,
So I managed to take off the headers of my 9ere and cleaned them and painted them nice.
But i'm having massive trouble putting them back on. I think i already shot one or two of the screw holes...
Anybody have any tips? Should i put the mid pipe section first or should i work on fitting the headers first?
Should I go about the messy way and remove the entire radiator...
Any tips are welcome. I'm super desperate...
Thanks!
ewmin3m is offline
post #2 of 13 Old 01-21-2015, 10:08 PM
I'm not sure whats causing your difficulty, but I always assemble everything loosely until everything is attached...then you can tighten everything up. Try hard not to strip out the stud holes on your engine...that would be considered a bad day.
post #3 of 13 Old 01-21-2015, 10:10 PM
Nickr919's Avatar
Take a brake and come back to it tomorrow. I've learned to know when im doing myself more harm than good to myself and my bike.
Nickr919 is offline
post #4 of 13 Old 01-21-2015, 10:22 PM Thread Starter
ewmin3m's Avatar
Ok finally got all the screws in and everything... It turns out they were just very dry and had to us a bit of force... Left them. In a bit of vinegar over the night to get all the crop off of them...
Panicked for no reason. I guess I was expecting them to screw on a lot easier I'll post pictures once I'm done... The paint job turned out quite nice
ewmin3m is offline
post #5 of 13 Old 01-22-2015, 06:27 AM
Call me OCD, but when I pull the header, I replace all of the nuts and always have a few extra studs on hand. They seem to strip out very easy.
jnich77 is offline
post #6 of 13 Old 01-22-2015, 11:18 AM Thread Starter
ewmin3m's Avatar
Before on the left and after on the right. It Looks pretty
I also kind of broke 2 of the screws example of one
File Type: jpg 10434173_357717731053219_7881960174437378234_n.jpg (185.4 KB, 46 views)
ewmin3m is offline
post #7 of 13 Old 01-22-2015, 11:34 AM
I must be missing something, what wrong with that "screw?" (no screws here, only studs and nuts sir)
post #8 of 13 Old 01-22-2015, 11:43 AM Thread Starter
ewmin3m's Avatar
The stud from the picture. I'm pretty sure I broke it because that threaded part never went through the head of the stud...
ewmin3m is offline
post #9 of 13 Old 01-22-2015, 12:17 PM
Negative! You just backed out the stud. Both ends are threaded so... yeah. Grab you a pair of nuts, run one on to the stud most of the way, then follow it up with another. Drive the nut furthest from the head against the next nut, and the stud will start turning in. The nuts might lock together giving you a fit taking it apart, but if you can get a wrench on both you can break the lock and back them out without disturbing the stud.
post #10 of 13 Old 01-22-2015, 01:19 PM Thread Starter
ewmin3m's Avatar
Ah ok. Thanks for the info. Can't I just leave it for now like that? I think I will... It only happened for two of the bolts... The rest are fine...
ewmin3m is offline
post #11 of 13 Old 01-22-2015, 01:48 PM
3dcycle's Avatar
when I did mine I replaced all the studs and nuts. lock tite on engine side and high temp anti seize on header side. feels good when a plan goes good.
and counting
3dcycle is offline
post #12 of 13 Old 01-22-2015, 02:00 PM
Total Awards: 17
Well, it depends. i wouldn't.
The right way to install headers is to back out 7mm flange nuts from studs, clean studs with wire brush (if came out) and put them back into the head, install new header gaskets ($3/ea) and new flange nuts (not mandatory but I would for $3/ea). I would also replace studs... why not for $3/ea? $60 in parts total and done once
It's impossible to torque flange nuts to the correct value with them being fused/rusted to studs, therefore one would never know if gaskets are compressed enough to seal the header.
In case you reused old header gaskets (which is doable), old flange locations (nuts fused to studs) are definitely not sealing properly at this point.
zaq123 is offline
post #13 of 13 Old 01-22-2015, 03:52 PM
I do this on every bike I pick up. Cheap and easy and prevents most future headaches.
