urgent help needed - Wrist Twisters
post #1 of 6 Old 06-22-2007, 12:21 AM Thread Starter
urgent help needed
hi folks,
if anybody out there i urgently need drawings for front suspension from service manual.hornet 2003.i will change fork oil from 5 to 7 and i need to know actual qty.
thanks george
GSCY is offline
post #2 of 6 Old 06-22-2007, 01:13 AM
Hola Como Estas?
ramrod's Avatar
Just click on the pics to make them bigger, I hate put file but I don't have any other host for the pics... hope this helps.
ramrod is offline
post #3 of 6 Old 06-22-2007, 01:47 AM Thread Starter
Ramrod,
You are the best.
Thank you!!!!! thumbup: .
you have save me.
regards
george
GSCY is offline
post #4 of 6 Old 06-22-2007, 05:21 AM
DaveCB919F4
Fastbackdlm's Avatar
If you set the fluid level by measuring fork compression. Then filling to that level below the fork cap. The air that is captive in the top of the fork will act as a progressive rate spring and help ride and handeling. I use zip ties around the fork tubes at the seal then compress to the stops and measure the distance the tie moved. It's important to have the levels the same. So even if you put in a measured quantity check level to top of tubes.
Fastbackdlm is offline
post #5 of 6 Old 06-22-2007, 05:37 AM Thread Starter
Fastbackdlm,
thanks for the tip.job is done by a mechanic so i hope he did it well.i will check it out with zip ties,good idea.i had the impresion that oil was a 5w but according to info above honda ss-8 is 10w.i finally deside to use 15w.i well let everybody know on monday if handling has been improved.at least diving
of front fork will be minimized.
thanks
GSCY is offline
post #6 of 6 Old 06-22-2007, 05:41 AM Thread Starter
Fastbackdlm,
thanks for tip.Job is allready done by a mechanic.Im sure he did everything
well.I will use zip ties just to be on safe site(good idea).
thanks
george
GSCY is offline
