Transmission knock - Wrist Twisters
post #1 of 31 Old 11-25-2008, 11:14 AM Thread Starter
Transmission knock
Just turned 1800 miles, coasting to a stop I hear a knock-knock-knock. It does it with the engine off or on, in gear or neutral, clutch in or out. It is NOT coming from the chain or sprockets, it is internal....did I get a lemon??!! Your opinions please.
mylifeon2wheels is offline
post #2 of 31 Old 11-25-2008, 12:25 PM
do you have a center or rear stand? You may be able to pinpoint the sound while turning the rear wheel with it on a stand. Does the knock change in relation to speed? How's your chain adjustment?
post #3 of 31 Old 11-25-2008, 01:13 PM Thread Starter
I don't have a stand, I can push it at a snails pace and hear a knock, knocks more the faster I push it.......chain adjusted OK, I keep it slightly loose. I checked the c/sprocket bolt torque...ok.... no uneven wear on the sprocket...it just sounds like it's coming internally.
post #4 of 31 Old 11-25-2008, 01:34 PM
Franklin McGillacutty
riquefied919's Avatar
When did you buy the bike? Honda has a 1 year warranty I'd look to big red if I were you.
riquefied919 is offline
post #5 of 31 Old 11-25-2008, 02:05 PM Thread Starter
I might have to.....I can hear it now: "they all do it" or some other kind of lip service. Bought it new 2 months ago.....marvelous.
post #6 of 31 Old 11-25-2008, 06:12 PM
Do you notice it only during braking?
Ripper is offline
post #7 of 31 Old 11-25-2008, 06:24 PM Thread Starter
Makes no difference whether the brakes are applied or not. Simply pushing the bike up my driveway produces a knock-knock-knock.....it would be a relief if someone else had the same problem....anyone?
post #8 of 31 Old 11-25-2008, 06:25 PM
9nineteen's Avatar
Donation BOTM
Are you saying you can hear the knocking over the engine noise? If you can, that's loud and it's something to be concerned with.
I'll have too clean sprockets and chain, though lubed, and the drive train would knock while pushing the bike around in the garage. . .but never while riding. If just smothered in lube, the drive train would be quiet while being pushed around.
I know you have less than 2k miles, but try lubing your chain. . .see what happens.
9nineteen is offline
post #9 of 31 Old 11-25-2008, 06:45 PM Thread Starter
If conditions are just right, I can just barely hear it knocking while coasting to a stop from about 10 mph. I'll lube the chain and see what happens. I know a superb M/C mechanic at an independant shop, I'll get his opinion. If it's a warranty issue, then it's back to the dealer. That's another issue, I've seen their techs......scary.
Thanks anyway guys.
post #10 of 31 Old 11-25-2008, 07:11 PM
I say its the chain.
Bryce919er is offline
post #11 of 31 Old 11-25-2008, 07:36 PM
Where are you at in SoCal? Lots of WT members with 919's around here, maybe one of us can swing by and listen to it.
post #12 of 31 Old 11-25-2008, 07:51 PM Thread Starter
That could work. I live in Chula Vista ( sorry). If you come to my 'hood, make sure your wearing neutral colors...wait, maybe safer to meet somewhere else. Seriously, that's a good idea you have, maybe when the weather clears or ??
Thanks.
post #13 of 31 Old 11-25-2008, 07:55 PM
919 City Pilot
Pegjumpflyer's Avatar
About that milage(1400)....one of my clutch bolts backed out (broken spring) hitting the case..... Look thru the oil cap and turn and look for loose / high bolts.
Metal everywhere eek~
Pegjumpflyer is offline
post #14 of 31 Old 11-25-2008, 08:07 PM
That was why I asked, I get a knock from the front end on braking once and a while. Thought it might have been the same thing?
Ripper is offline
post #15 of 31 Old 11-25-2008, 08:14 PM
Thanks.
I live in Escondido. Miramar or Kearny Mesa would be about halfway. Fun Bike Center maybe? After tomorrow, I'll be free the rest of the week except Saturday.
post #16 of 31 Old 11-25-2008, 08:25 PM
Thanks.
if he lived in san fran it would be called "culo vista"... lol or "culito vista".....
no se cual es lo mejor..
post #17 of 31 Old 11-25-2008, 08:28 PM Thread Starter
Good suggestion BUT the clutch does not rotate with the engine off and in neutral....that's one of the conditions when I get the knock. Thanks
SUGS.....thanks for the offer.....I'll try lubing the chain first, if no-go then maybe we could meet at FBC Friday(?) or ???? I'm flexible (and retired) so whenever convenient with you.....stay tuned, I'll let you know how the lube treatment works. Too bad, I love this bike.
post #18 of 31 Old 11-25-2008, 08:30 PM
i hope it is only in need of some lube.. i used to work in a dealership....
post #19 of 31 Old 11-25-2008, 11:05 PM
05superblackz's Avatar
Don't know if someone has already said it, check to see if your chain is lubed properly. I had something similar and I checked the tightness of the chain and my sprokets, and it all looked good. Then I realized how many miles I had since my last lube, and it cleared right up.
05superblackz is offline
post #20 of 31 Old 11-26-2008, 02:58 AM
If the clutch isn't rotating and your bike isn't in gear, it cannot be the tranny.
My wheel bearings kind of sounded like that on their way out. But you don't have enough miles for that problem.
I wish I could be of some help. Let us know what you find out.
post #21 of 31 Old 11-26-2008, 08:59 AM
PHOBMAN's Avatar
I wonder if the countersprocket has picked up some debris that's going round and round?
PHOBMAN is offline
post #22 of 31 Old 11-26-2008, 09:48 AM Thread Starter
Update: I removed the c/sprocket cover and took a close look. It appears that the chain was not perfectly aligned with the teeth,i,e, the chain would ride hide then drop possibly causing it to knock. I cleaned the sides of the sprocket and applied some grease, lubed the chain AGAIN. I pushed it up and down the driveway and no knock.....I will road test when the weather clears.Thanks to everyone for your helpful suggestions.
post #23 of 31 Old 11-26-2008, 11:31 AM
They all do that!
Actually new owners do that. We get a lot of new owners that hear something that sets off all sorts of false alarm.
If the counter was not perfectally alligned with the chain, did you align it? How?
post #24 of 31 Old 11-26-2008, 02:00 PM Thread Starter
No more knocking......for the first 20 ft anyway. It returned with a vengance. Took it straight to the dealer. Service Manager hears it "Hmmm....thats not good". I told him where I stood: If it's anything beyond a simple repair, Honda has 2 choices: Buy it back or replace with a new one. "I agree but it's not my call"..............now the fun begins. Oh well, I still have my trusty old Nighthawk.
post #25 of 31 Old 11-26-2008, 02:11 PM
good luck... and don't let them jerk you around..
post #26 of 31 Old 11-26-2008, 05:22 PM Thread Starter
My driveline knock is now history. According to the service manager and Honda Corp., the splined portion of the c/sprocket should have had a coating of grease, which they found dry on removal. They cleaned and greased everything, rode it home, all is well. I'm impressed with the speed and level of service, guess I'll have to eat my words. If you get a knock in the driveline you now know where to look. Thanks for your help guys.
post #27 of 31 Old 11-26-2008, 06:44 PM
Glad is was a nice easy fix.
post #28 of 31 Old 11-26-2008, 07:19 PM
glad to hear you live near a good dealer. The one here hasn't fixed their blown-over sign in 3 months so I wonder how long it would take for them to actually fix something for me.
post #29 of 31 Old 11-27-2008, 07:54 PM
You know, it sounds hoaky, but your service man did was probably right on the money. I'm pretty sure the front sprocket does move on the shaft a bit.
I've never heard of that one before. Thanks for sharing.
post #30 of 31 Old 11-30-2008, 06:04 PM
Sounds like a good fix but can someone expand on this sprocket side to side movement on the shaft please…
I would have thought as required per spec when one is to torque down the c/sprocket bolt (with washer) it would press the sprocket on to the backside of the drive shaft, and hold it in place.. How would it move????...
This kinda goes to my issue I have with my Renthal sprockets..(which I keep on forgetting to email Renthal about)
Last summer I changed out my front and rear sprockets with a set form Renthal, and just this summer when I was packing the bike away for the session, and cleaning out the centre sprocket area, I noticed that c/sprocket moves on the drive shaft side to side about 1mm…
I have no perceived problems with the side to side movement, but as noted above, with my Renthal c/sprocket, the bolt/washer that is to hold the sprocket in place is not really being torque down as the washer is not touching the side of the sprocket. Essentially the bolt is just torqued down on the end of the shaft.
I drew up a PRETTY picture to help
What do you guys think?
I knew I should have kept the OEM sprocket to compare! Anyone have an original OEM sprocket that can measure the width of the sprocket? As I will be emailing Renthal and ask them to compare the OEM width to their replacement c/sprocket
CB900F2 is offline
post #31 of 31 Old 11-30-2008, 06:20 PM
it is supposed to have a touch of play in it to keep it from binding etc.... mine has a touch of play... the cbr1000 i had had a touch of play.. so did the 1997 kawa zx6r i had...
now if your REAR sprocket has play... then there are problems..lol
