Tranny clunk - Wrist Twisters
post #1 of 24 Old 08-29-2007, 09:00 PM Thread Starter
Keyf
ktsubouchi's Avatar
Tranny clunk
I have a 2006 919. Say, for example, I'm at a stop light. I'm in first and the clutch is disengaged. When the light turns green and I start to let go of the clutch lever...<clunk>.
or
Stop light and neutral. Clutch in and shift to first...<big clunk>
Is all of this normal? Cause I feel like if it clunks too much, I'll shear the teeth of some gear.
ktsubouchi is offline
post #2 of 24 Old 08-29-2007, 09:12 PM
Mc 9er
mcdonald919's Avatar
clunking from neut to 1st sounds normal,not sure what you mean by clunk when you release clutch,unless maybe it was'nt fully in gear to begin with and slid(or clunked)in when you started to movethats just my uneducated guess
c 9er
silver,the fasted colour
mcdonald919 is offline
post #3 of 24 Old 08-30-2007, 03:24 AM
3dcycle's Avatar
yea that sounds about right. check your clutch lever freeplay, and your idle adjustment. you may beable to quiet it down a little bit.
3dcycle is offline
post #4 of 24 Old 08-30-2007, 03:26 AM
Newfie
karlb63's Avatar
All good... and normal. BTW that "Clunk" sounds cool. I have a 06 as well. The only prob I had was when shifting too quick at higher gears... it would slip into neutral and then rattle the gear before engaging. I slowed down my shift and hasn't done it since.
karlb63 is offline
post #5 of 24 Old 08-30-2007, 03:41 AM
3dcycle's Avatar
yea every so often i would miss a shift too, but normally i could feel it before i fully engaged clutch so i would just pull it back in, and try onemore time. i know its no good for clutch but i can replace clutch under $100 way under actually. but i dont want to replace gears in tranny.
3dcycle is offline
post #6 of 24 Old 08-30-2007, 05:18 AM
The "big clunk" at a stop going into first is normal. The tranny shifts better when moving.
The "clunk" if it's already in gear and you're just letting the clutch out to leave a stop is probably one of two things:
Too much chain slack.
Cush drive taking up slack.
post #7 of 24 Old 08-30-2007, 05:27 AM
Dang
Boston919er's Avatar
ah, the old clunk question. Im begining to feel old around here....
I was nervous at first when I got my 919, now I love when Im at a stop light and drop it into first. LOVE THE CLUNK
Boston919er is offline
post #8 of 24 Old 08-30-2007, 05:32 AM
it took about 2000 miles on my 06 before it started to shift smoothly. I'm sure part of it was me but things still need to loosen up sometimes. Chain slack is easy to check.
Lemonhead is offline
post #9 of 24 Old 08-30-2007, 07:24 AM
BrokeRecord
Clunk
Karl and 3D, I thought I had bought a lemon the 1st 1500 miles. I'd shift 4-5 or 5-6 and it sounded like the guts would splatter all over me and the road! The 1st time I got severe pucker action and clutched and drifted to a stop, thinking I was gonna slip and fall any second in the gear oil. I remembered what Mike Wheeler said about the trans taking longer to break-in and give it about 2500 miles. Now all smooth,but, I may lower the idle about 100 rpms.
brokerecord is offline
post #10 of 24 Old 08-30-2007, 07:37 AM
Up until I bought my first v-twin motorcycle last month, I've had the "clunk" with every bike I've ever owned.
My '82 CB900F tranny - bag o' rocks
My 85 Interceptor 500 tranny - bushel o' rocks
Both my '85 Nighthawk S trannies - knapsacks o' rocks
My '87 Hurricane 600 tranny - sack 'o rocks
My '02 FZ1 tranny - box o' rocks
The tranny in my new RoadStar is the first bike I've ever owned with a truly "silky, smooth-shifting" transmission. Never a clunk, nary a sound moving through any gear, up or down.
I've noticed the same thing on my buddy's Warrior, and even my other buddy's POS Heritage Softail shifts like butter.
Is it simply less moving parts in the tranny? What's the dilly-yo?!?!
JohnnyLfromCT is offline
post #11 of 24 Old 08-30-2007, 08:43 AM
wisco919's Avatar
I would have to agree that cruiser's trans are smoother in comparison to most of the sportier bikes I have ridin. Heck my Yamaha Quad has smoother feeling shift then 9er.
wisco919 is offline
post #12 of 24 Old 08-30-2007, 08:55 AM
Don't have any clunks when letting out the clutch, but I got them when going into first gear and shifting from first to second. Also, anyone else here ever hear a low rumbling sound from the tranny when you are in neutral and have let go of the clutch?
post #13 of 24 Old 08-30-2007, 09:53 AM
clutch rattle. Normal.
post #14 of 24 Old 08-30-2007, 10:22 AM
Clunk, rattle & roll !!
Hondas do a "clunk, rattle & roll"
vs.
the HD's "shake, rattle & roll"
05919er is offline
post #15 of 24 Old 08-30-2007, 11:31 AM
async's Avatar
I used to have one of those too, mine was also like a box of rocks.
async is offline
post #16 of 24 Old 08-30-2007, 08:31 PM
Thats my issue. Not that I am trying to be scarce or a dick... and I know the new guys have the same probs as the veterans but it just feels like we continue to beat the same horse to death.
honda NEEDS to give us a new 919 to figure out all the little quirks.
typhoonblue919 is offline
post #17 of 24 Old 08-30-2007, 10:35 PM
Go'n So slow I'm stopped
xrmikey's Avatar
Mine only "clunks" going into first.
Very faint rattel at times from the clutch.
Other than that, it's fine.
Shifts better with Repsol oil than HP4.
xrmikey is offline
post #18 of 24 Old 08-31-2007, 01:11 PM
If you are routinely hitting false neutrals between gears 99&#37; of the time that is simply operator error because you are not shifting properly. Some guys have taken offense to me saying that cause they have been riding for 30+ years & think they know how to shift a bike, but under closer examination they figure out they it was lazy shifting causing the problem rather than an actual transmission problem which is VERY rare on these bike unless of course you are abusing them with clutchless upshifts also done improperly etc... Some riders have even discovered that they only have mis-shifts when they wear a certain pair of boots etc because the sole of the boot is higher or lower than normal & puts their foot at a different angle on the shift lever.
Excessive driveline lash while you are in motion can be caused by play in the cush drive or too much chain slack, but again the most common cause is the rider allowing too much time between the time he shifts into the next gear before he gets back on the throttle. There is no coasting in motorcycle racing. You should be on the brakes or on the gas in most cases & if you are coasting into a turn or in between shifts then you are putting the engine inbetween postive or negative load through the tranny & building up slack internally. When you finally get back on the gas the slop inside the transmission has to be taken out as well as the slack in the chain & cush drive all of which can lead to a lot of herky jerky motion from your bike.
Another tangent of this problem we have encountered are riders that are babying the bike way too much & short shifting every gear at 3000 or 4000 rpm etc... Quite frankly the bikes transmission was designed for high rpm shifting & low rpm shifting is plain going to be notchy.
If your engine idle is set too high it will cause a larger than normal clunk when slipping into first gear from a dead stop, but that clunk is a normal part of the transmission engagement.
Clutches are very noisy even wet clutches & yes they are quite audible when you engage (let the lever out) the clutch in neutral so that faint rattle you hear is again perfectly normal.
post #19 of 24 Old 08-31-2007, 01:29 PM
Corner speed sets u free
streakin919's Avatar
very true and i suspect your idle is too high hense your nuet to 1st clunk. idle should be around 1k +/-200 i believe... i keep mine around 1k and it does lessen the clunk from Nuetral to 1st.
streakin919 is offline
post #20 of 24 Old 08-31-2007, 01:41 PM
2006 919
thank you for the good information.
some newbie questions
where is the right place to shift on the 919 (what rpm?)
city? highway?
for the clunk I also find if I have trouble shiftin into first if I move the bike back a few inches it slips right in.
monsieur net is offline
post #21 of 24 Old 08-31-2007, 04:47 PM
city? highway?
A perfect shift in racing is shifting each gear just before the rev limiter. On the street you don't need to go that far with it. just depends on your objective at any given point in your ride. for Ex. if you need maximum acceleration and forward movement because you're running from a Godzilla attack on your city then race shift it, if you're just cruising in traffic then short shifting a little is necessary. I ride by feel with 9ner so i don't pay attention to the tach when i'm shifting on the street.
Oh and you might want to check your idle and if that doesn't help then check your clutch adjustment.
post #22 of 24 Old 08-31-2007, 05:50 PM
Thanks for the great information and advice, LDH and Streak. My idle is set just at a hair above 1k. I might lower it a little see what happens.
post #23 of 24 Old 08-31-2007, 06:45 PM
2006 919
my idle is fine running about 1000+ 100 approx.
I am glad to read here that everybody gets the clunk.
( I can sleep at night now, well after seeing the 919 in the tootoo maybe not so well)
I do alot of city driving, I have to say up till now, I have been low shifting, in the city, and letting the rpms go a little higher on the highways and backroads.
I will try to shift a little higher around town.
mr. clean
post #24 of 24 Old 09-03-2007, 12:46 PM
I highly recommend once you've got it broken in, get out of town and experiment with the higher end of the band.
(pssst, it's fun)
